| mrhurtalot |
Aug 20 2007, 02:38 AM
VRRRRRRROOOOOOOOOM! ![]() ![]() Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
ive got my tranny back from the shop. and tommorrow ill be heading home from school to put it in.
ive tried last week, but it just would slide all the way on. i could get it on the bolts and it would get stuck about an inch or so from being completely on. the shop opened the case and replaced some stuff, do you guys think i just need to move the spindle around a bit? any tips will help alot. (IMG:style_emoticons/default/bye1.gif) |
| jr91472 |
Aug 20 2007, 09:31 AM
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
With the trans in gear, try rotating the axle hubs a bit. Shouldn't take much, but just enough to rotate the "spindle" as you call it.
Should go on pretty easy, so don't force it. Sometime it can be a difficult to get every thing aligned (laying under the car, holding up a tranny, etc). Did you remove the clutch at all (you said tranny work, but didn't mention anything else)? If so, follow Joe's advice and make sure the clutch disk is aligned properly. good luck! |
mrhurtalot tranny reinstall trouble Aug 20 2007, 02:38 AM
Joe Ricard Correct throw-out bearing?
Are you using the align... Aug 20 2007, 05:58 AM
tdgray :agree: 99.5% of the time the clutch disk is not a... Aug 20 2007, 09:48 AM
mrhurtalot is it not called a "spindle"? hmmm then ... Aug 20 2007, 11:09 AM
davep BTDT. I find it much easier to pull the engine ... Aug 20 2007, 11:32 AM
Joe Ricard Jacks.
Last time I stabbed a transaxle to an in... Aug 20 2007, 12:43 PM
Cap'n Krusty The big trick is to support the tranny at the cent... Aug 20 2007, 12:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 07:59 AM |
