| mrhurtalot |
Aug 20 2007, 02:38 AM
VRRRRRRROOOOOOOOOM! ![]() ![]() Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
ive got my tranny back from the shop. and tommorrow ill be heading home from school to put it in.
ive tried last week, but it just would slide all the way on. i could get it on the bolts and it would get stuck about an inch or so from being completely on. the shop opened the case and replaced some stuff, do you guys think i just need to move the spindle around a bit? any tips will help alot. (IMG:style_emoticons/default/bye1.gif) |
| davep |
Aug 20 2007, 11:32 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,359 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
BTDT. I find it much easier to pull the engine & tranny as a package to do that work. If nothing else it is easier on the motor mounts. Usually it is just an alignment problem. Try & try again. Rotate the flywheel a little each time.
mrhurtalot tranny reinstall trouble Aug 20 2007, 02:38 AM
Joe Ricard Correct throw-out bearing?
Are you using the align... Aug 20 2007, 05:58 AM
jr91472 With the trans in gear, try rotating the axle hubs... Aug 20 2007, 09:31 AM
tdgray :agree: 99.5% of the time the clutch disk is not a... Aug 20 2007, 09:48 AM
mrhurtalot is it not called a "spindle"? hmmm then ... Aug 20 2007, 11:09 AM
Joe Ricard Jacks.
Last time I stabbed a transaxle to an in... Aug 20 2007, 12:43 PM
Cap'n Krusty The big trick is to support the tranny at the cent... Aug 20 2007, 12:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 07:57 AM |
