purple |
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None ![]() |
Hey Guys,
I'm curious if my clutch cable is out of threads at the tranny end. I've drawn what can best be described as the best pen-paper drawing ever. This illustrious illustration illustrates the indignant state of my clutch linkage exactly. The arm that goes to the clutch is all the way against the back of the cable. If I move the arm closer to the end of the threads, what does that do? (to the right in the picture) If I move the arm closer to the back of the car, what does that do? (to the left in the picture) I'd like your guys input because the haynes manual kinda glosses over this part. If I'm out of threads, does that mean I'll be replacing the clutch soon? Thanks guys! Attached thumbnail(s) ![]() |
purple |
I think for now i'm going to deal with the pedal to the floor nonsense and when i've got enough, drop the whole thng out of the car and put a new clutch in, TOB, pressure plate, flywheel, all the little itsy bits that are busteded and so on.
There is so much that was just let go by the P.O. it's sad. he fused a link off like the stereo fuse on the fuse panel to run the fuel pump.... put motorcycle exhaust on it bedlinered the interior the steering column has up/down play jury-rigged a BRB starter (big red button), necessitating running FOUR thick wires put the temp sender wire into the wiring harness, and then didnt pull it out in the engine bay... the left front suspension is loose and i can hear it banging around it's quite possibly a bus engine in my car WITH hydraulic lifters with missing left side cylinder ducting off the engine tin and the coup de grace.... weber progressive the list goes on. |
Lo-Fi Version | Time is now: 13th June 2024 - 02:35 AM |
