> Another "taco plate" question, Update: job complete, but is gauge accurate?
Cevan
post Aug 27 2007, 07:57 AM
I have '75 1.8 that the PO installed a nice center console complete with gauges. The volt meter works, clock didn't until I pulled it out and found the ground wire disconnnected. Now it keeps perfect time.
There is a plate currently where the oil temp sending unit goes. I also have a oil temp sending unit. I believe the order of installation is the red o-ring, the sending unit itself, the gasket and then black cover. I'm assuming I ground the black cover and the lead from the gauge goes to the sending unit.
I can't seem to locate that wire. I'm assuming that the oil temp lead goes thru the center tunnel into the engine compartment. Where should I look? Will a ground wire also be with it? What color should the wires be? Brown=ground?
Cap'n Krusty
post Aug 27 2007, 09:57 AM
Cap'n Krusty
The green/black wire comes up through the body below the battery, and should have a rectangular translucent plastic insulator over the male connector. From there, your connecting wire goes through the throttle cable hole, and across the lower front of the engine to the sender. It's held in place by a couple of small brackets similar to the one on the cover. DO NOT forget the special 6mm crush washers for the bolts holding the sender assembly to the engine case.
The Cap'n
Cevan   Another "taco plate" question   Aug 27 2007, 07:57 AM
So.Cal.914   There should only be one wire for the temp gauge, ...   Aug 27 2007, 08:29 AM
Cevan   I was hoping there was a wire in the engine compar...   Aug 27 2007, 08:43 AM
So.Cal.914   Not sure if the 75 loom had the wire run for it or...   Aug 27 2007, 08:52 AM
Spoke   I added an oil temp gauge in my 71 and found that ...   Aug 27 2007, 09:02 AM
Cap'n Krusty   The green/black wire comes up through the body bel...   Aug 27 2007, 09:57 AM
Cevan   The green/black wire comes up through the body be...   Aug 27 2007, 10:50 AM
Cap'n Krusty   While they won't have the washers in stock, I...   Aug 27 2007, 11:01 AM
Cevan   Can a generic crush washer be used? If so, where ...   Aug 27 2007, 11:12 AM
Cap'n Krusty   Can a generic crush washer be used? If so, where...   Aug 27 2007, 11:31 AM
Cevan   Just ordered the oil drain plug washers ($.88...   Aug 27 2007, 12:45 PM
GTPatrick   3 questions for y'all who are following this t...   Aug 27 2007, 12:55 PM
Cevan   3 questions for y'all who are following this ...   Aug 27 2007, 01:32 PM
Cevan   3 questions for y'all who are following this ...   Sep 14 2007, 06:22 AM
So.Cal.914   I do not recall that, but there were some tabs I...   Sep 14 2007, 06:36 AM
SLITS   The sender is the variable ground for the guage. ...   Sep 14 2007, 07:46 AM
Cevan   Ahhhh, the metal tab on the black outer plate hold...   Sep 14 2007, 08:11 AM
Cevan   Someone wanted pictures of this procedure so here ...   Sep 15 2007, 11:12 AM
So.Cal.914   :clap:   Sep 15 2007, 12:35 PM
SirAndy   might not be ideal to route the wire through the h...   Sep 15 2007, 03:22 PM
Mike914   Guys, I think I posted pics of the wire routing in...   Sep 15 2007, 05:25 PM
Cevan   might not be ideal to route the wire through the ...   Sep 15 2007, 08:53 PM
Cevan   My oil temp gauge is a VDO but without the numbere...   Sep 18 2007, 03:17 PM
Grelber   That's about right. Mine runs between the ...   Sep 18 2007, 04:03 PM
- Lo-Fi Version Time is now: 16th June 2024 - 08:31 PM
