> throttle cable trouble, sleeve broken, stuck in tube...
lotus_65
post Aug 29 2007, 06:00 PM
My throttle cable broke at the carb linkage so it needed to be replaced. No big deal, right?
Unfortunately the white plastic sleeve is broken at the firewall and WILL NOT BUDGE. Won't pull, won't push.
I can (barely) get a needle nose on it, but it seems bound up inside the tube somewhere. I haven't pulled the cable out of the sleeve yet, as I had hoped to attach a string to help the new cable into place.
I also dis-assembled the interior to get at the tunnel from the shifter, but there's no obvious advantage there. I ALMOST bought a sawzall to cut another access panel there, but came off that ledge... for now.
What a PITA. (IMG:style_emoticons/default/headbang.gif)
Anyone?
paul
lotus_65
post Aug 30 2007, 08:31 AM
Thanks for the new cable, chappy~
After sleeping on it, here are the things I plan on doing:
First, I'll try adding a washer to the pedal assembly end that is slightly smaller than the I.D. of the tube and try to pull the assembly towards the back. If I can get a little sheath to emerge I can get a vice grip on it and start twisting/working it out.
I might add some heat to the tunnel in hopes of expanding the steel tube and loosening it's grip on the sheath.
If that doesn't work, I'll roughen the cable or add some type of barbs to it and reinsert it from the firewall hoping to find grip when I pull it back out.
If all else fails I'll use the cable as a reamer on my drill and grind the sheath from the inside. I don't want to do this, it'll be a stinking mess and I'll have no assurances that I get the whole sheath out, but it's all I can think of.
Maybe I'll take some pics...
lotus_65   throttle cable trouble   Aug 29 2007, 06:00 PM
Cap'n Krusty   First of all, using the old cable to pull a new on...   Aug 29 2007, 06:59 PM
lotus_65   I was hoping you'd chime in, Cap'n! i ...   Aug 29 2007, 07:31 PM
lotus_65   :bump: :)   Aug 30 2007, 02:14 AM
iamchappy   Need help.....   Aug 30 2007, 08:04 AM
lotus_65   Thanks for the new cable, chappy~ After sleeping ...   Aug 30 2007, 08:31 AM
lotus_65   ... so it looks like i'll have to drop the fcu...   Sep 1 2007, 03:47 AM
lotus_65   ...so who knew i'd have to drop the motor? w...   Sep 3 2007, 06:30 PM
iamchappy   No way you should have to drop the engine to fix t...   Sep 3 2007, 08:35 PM
jhadler   Little did I know that I'd find myself in a si...   Sep 9 2007, 02:41 PM
Brando   I had the same problem when my throttle cable brok...   Sep 9 2007, 02:53 PM
jhadler   Okay, cable in... I had problems with the threade...   Sep 9 2007, 03:38 PM
Brando   To get mine back in, had to use a long 1/8" d...   Sep 9 2007, 04:07 PM
lotus_65   i haven't checked this thread in a while, stil...   Sep 9 2007, 06:34 PM
lotus_65   lastly, i determined the throttle cable hat was ne...   Sep 9 2007, 06:41 PM
jhadler   So... now why is my brand new throttle cable stick...   Sep 10 2007, 03:03 PM
lotus_65   josh2, my guess is that the throttle cable is wrap...   Sep 10 2007, 06:41 PM
jhadler   I thought that. But I figured that if I didn't...   Sep 10 2007, 06:49 PM
lotus_65   maybe try and position a mirror down there with a ...   Sep 10 2007, 07:10 PM
2-OH!   I used the isolation trick, isolate the problem fi...   Sep 11 2007, 02:40 PM
- Lo-Fi Version Time is now: 14th July 2025 - 03:46 AM
