lotus_65 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,609 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region ![]() |
My throttle cable broke at the carb linkage so it needed to be replaced. No big deal, right?
Unfortunately the white plastic sleeve is broken at the firewall and WILL NOT BUDGE. Won't pull, won't push. I can (barely) get a needle nose on it, but it seems bound up inside the tube somewhere. I haven't pulled the cable out of the sleeve yet, as I had hoped to attach a string to help the new cable into place. I also dis-assembled the interior to get at the tunnel from the shifter, but there's no obvious advantage there. I ALMOST bought a sawzall to cut another access panel there, but came off that ledge... for now. What a PITA. (IMG:style_emoticons/default/headbang.gif) Anyone? paul |
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
No way you should have to drop the engine to fix the cable, I offered to help.
Dont sell your car over this.... |
Lo-Fi Version | Time is now: 14th July 2025 - 03:24 AM |
