lotus_65 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,609 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region ![]() |
My throttle cable broke at the carb linkage so it needed to be replaced. No big deal, right?
Unfortunately the white plastic sleeve is broken at the firewall and WILL NOT BUDGE. Won't pull, won't push. I can (barely) get a needle nose on it, but it seems bound up inside the tube somewhere. I haven't pulled the cable out of the sleeve yet, as I had hoped to attach a string to help the new cable into place. I also dis-assembled the interior to get at the tunnel from the shifter, but there's no obvious advantage there. I ALMOST bought a sawzall to cut another access panel there, but came off that ledge... for now. What a PITA. (IMG:style_emoticons/default/headbang.gif) Anyone? paul |
jhadler |
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 ![]() |
I thought that. But I figured that if I didn't feel any motion or vibration in the throttle cable when actuating the clutch, that the clutch cable wasn't involved. I could be wrong, and if I can figure out a way to take a look in there, I'll definitely be doing that. Of course, that's the most likely spot for trouble... So I'll probably pull it and reinsert it...
-Josh2 |
Lo-Fi Version | Time is now: 14th July 2025 - 03:20 AM |
