> Another "taco plate" question, Update: job complete, but is gauge accurate?
Cevan
post Aug 27 2007, 07:57 AM
I have '75 1.8 that the PO installed a nice center console complete with gauges. The volt meter works, clock didn't until I pulled it out and found the ground wire disconnnected. Now it keeps perfect time.
There is a plate currently where the oil temp sending unit goes. I also have a oil temp sending unit. I believe the order of installation is the red o-ring, the sending unit itself, the gasket and then black cover. I'm assuming I ground the black cover and the lead from the gauge goes to the sending unit.
I can't seem to locate that wire. I'm assuming that the oil temp lead goes thru the center tunnel into the engine compartment. Where should I look? Will a ground wire also be with it? What color should the wires be? Brown=ground?
GTPatrick
post Aug 27 2007, 12:55 PM
3 questions for y'all who are following this thread .
1 - Does anyone have a picture of the actual installation of the sending unit on the taco plate ?
2 - Does anyone have any pictures of the routing of the wireloom in the engine compartment from the firewall back to the sending unit ? (IMG:style_emoticons/default/blink.gif)
3 - Would it not be easier to route the wire from the indicator under the carpeting along the tunnel and drill a hole in thefireewall using a rubber grommet to allow the wire to pass thru it ? (IMG:style_emoticons/default/huh.gif)
Thanks . (IMG:style_emoticons/default/beer.gif)
Cevan
post Sep 14 2007, 06:22 AM
QUOTE(GTPatrick @ Aug 27 2007, 10:55 AM) *
I found the wire next to the resistor pack below the battery, just where it was supposed to be. I finally got the crush washers for the 2 bolts and the aluminum washer for the sensor itself. Last night I hooked up the sensor outside the car and put it in near-boiling water and the gauge needle responded. (IMG:style_emoticons/default/smilie_pokal.gif)
My next question is do I need the black outer plate. It seems to have a place for a ground wire to be inserted, but I would think that if the sensor and inner plate were installed, the sensor would already be grounded. Do I need the black plate and gasket installed to keep the oil in the engine??
Cevan   Another "taco plate" question   Aug 27 2007, 07:57 AM
So.Cal.914   There should only be one wire for the temp gauge, ...   Aug 27 2007, 08:29 AM
Cevan   I was hoping there was a wire in the engine compar...   Aug 27 2007, 08:43 AM
So.Cal.914   Not sure if the 75 loom had the wire run for it or...   Aug 27 2007, 08:52 AM
Spoke   I added an oil temp gauge in my 71 and found that ...   Aug 27 2007, 09:02 AM
Cap'n Krusty   The green/black wire comes up through the body bel...   Aug 27 2007, 09:57 AM
Cevan   The green/black wire comes up through the body be...   Aug 27 2007, 10:50 AM
Cap'n Krusty   While they won't have the washers in stock, I...   Aug 27 2007, 11:01 AM
Cevan   Can a generic crush washer be used? If so, where ...   Aug 27 2007, 11:12 AM
Cap'n Krusty   Can a generic crush washer be used? If so, where...   Aug 27 2007, 11:31 AM
Cevan   Just ordered the oil drain plug washers ($.88...   Aug 27 2007, 12:45 PM
GTPatrick   3 questions for y'all who are following this t...   Aug 27 2007, 12:55 PM
Cevan   3 questions for y'all who are following this ...   Aug 27 2007, 01:32 PM
Cevan   3 questions for y'all who are following this ...   Sep 14 2007, 06:22 AM
So.Cal.914   I do not recall that, but there were some tabs I...   Sep 14 2007, 06:36 AM
SLITS   The sender is the variable ground for the guage. ...   Sep 14 2007, 07:46 AM
Cevan   Ahhhh, the metal tab on the black outer plate hold...   Sep 14 2007, 08:11 AM
Cevan   Someone wanted pictures of this procedure so here ...   Sep 15 2007, 11:12 AM
So.Cal.914   :clap:   Sep 15 2007, 12:35 PM
SirAndy   might not be ideal to route the wire through the h...   Sep 15 2007, 03:22 PM
Mike914   Guys, I think I posted pics of the wire routing in...   Sep 15 2007, 05:25 PM
Cevan   might not be ideal to route the wire through the ...   Sep 15 2007, 08:53 PM
Cevan   My oil temp gauge is a VDO but without the numbere...   Sep 18 2007, 03:17 PM
Grelber   That's about right. Mine runs between the ...   Sep 18 2007, 04:03 PM
- Lo-Fi Version Time is now: 16th June 2024 - 08:38 PM
