Another "taco plate" question, Update: job complete, but is gauge accurate? |
Cevan |
Aug 27 2007, 07:57 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I have '75 1.8 that the PO installed a nice center console complete with gauges. The volt meter works, clock didn't until I pulled it out and found the ground wire disconnnected. Now it keeps perfect time.
There is a plate currently where the oil temp sending unit goes. I also have a oil temp sending unit. I believe the order of installation is the red o-ring, the sending unit itself, the gasket and then black cover. I'm assuming I ground the black cover and the lead from the gauge goes to the sending unit. I can't seem to locate that wire. I'm assuming that the oil temp lead goes thru the center tunnel into the engine compartment. Where should I look? Will a ground wire also be with it? What color should the wires be? Brown=ground? |
SLITS |
Sep 14 2007, 07:46 AM
The sender is the variable ground for the guage. The ground for the sensor is the taco plate assembly and the two attaching fastners. A single wire from the sender, across the front of the engine to the connector under the battery. That's it.
Lo-Fi Version | Time is now: 16th June 2024 - 07:16 PM |
