Identifying engine, serial doesnt match pelicans? |
stateofidleness |
Sep 17 2007, 08:18 PM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
i found the serial number on my engine and im having trouble identifying it. i tried comparing it to the FAQ on Pelican:
"A very good indicator of what type of four-banger you have is the engine code. The engine code is located in front of the oil filler, between it and the fan shroud, on 2.0L cases. The code should start with "GA" (for 73-74) or "GC" (for 75-76). The European 2.0L engine code starts with "GB". The 1.7L and 1.8L engine codes are on a flat spot located toward the right-rear of the top of the case. You may have to push some hoses and wires out of the way, and clean off a lot of dirt to read them. 1.7L engine codes start with "W", "EA", or "EB" (for the 73 California car). The 1.8L codes start with "EC" for the US model, or "AN" for the European model." now im pretty sure mine is: 6A012526 so far ive been under the impression that this is a '76 can anyone help clarify? |
Dave_Darling |
Sep 18 2007, 01:47 AM
2.0 case, 2.0 air cleaner, 2.0 manifold and throttle body... Yeah, that'd be the way to bet! How about the heads? I can't really see the plug wires or the intake studs; are there three studs or four holding the intake runner pipes onto the heads? Do the plugs come out the sides of the engine tin, or the horizontal top parts?
--DD |
Lo-Fi Version | Time is now: 10th June 2024 - 08:28 AM |
