> Another "taco plate" question, Update: job complete, but is gauge accurate?
Cevan
post Aug 27 2007, 07:57 AM
I have '75 1.8 that the PO installed a nice center console complete with gauges. The volt meter works, clock didn't until I pulled it out and found the ground wire disconnnected. Now it keeps perfect time.
There is a plate currently where the oil temp sending unit goes. I also have a oil temp sending unit. I believe the order of installation is the red o-ring, the sending unit itself, the gasket and then black cover. I'm assuming I ground the black cover and the lead from the gauge goes to the sending unit.
I can't seem to locate that wire. I'm assuming that the oil temp lead goes thru the center tunnel into the engine compartment. Where should I look? Will a ground wire also be with it? What color should the wires be? Brown=ground?
Grelber
post Sep 18 2007, 04:03 PM
Insert favorite Don Rickles joke here.
That's about right. Mine runs between the "T" and the "E", even on hot days here in Texas. If you search, I seem to remember a thread where someone had done a conversion that had shown the actual temps for each letter on that gauge.
Cevan   Another "taco plate" question   Aug 27 2007, 07:57 AM
So.Cal.914   There should only be one wire for the temp gauge, ...   Aug 27 2007, 08:29 AM
Cevan   I was hoping there was a wire in the engine compar...   Aug 27 2007, 08:43 AM
So.Cal.914   Not sure if the 75 loom had the wire run for it or...   Aug 27 2007, 08:52 AM
Spoke   I added an oil temp gauge in my 71 and found that ...   Aug 27 2007, 09:02 AM
Cap'n Krusty   The green/black wire comes up through the body bel...   Aug 27 2007, 09:57 AM
Cevan   The green/black wire comes up through the body be...   Aug 27 2007, 10:50 AM
Cap'n Krusty   While they won't have the washers in stock, I...   Aug 27 2007, 11:01 AM
Cevan   Can a generic crush washer be used? If so, where ...   Aug 27 2007, 11:12 AM
Cap'n Krusty   Can a generic crush washer be used? If so, where...   Aug 27 2007, 11:31 AM
Cevan   Just ordered the oil drain plug washers ($.88...   Aug 27 2007, 12:45 PM
GTPatrick   3 questions for y'all who are following this t...   Aug 27 2007, 12:55 PM
Cevan   3 questions for y'all who are following this ...   Aug 27 2007, 01:32 PM
Cevan   3 questions for y'all who are following this ...   Sep 14 2007, 06:22 AM
So.Cal.914   I do not recall that, but there were some tabs I...   Sep 14 2007, 06:36 AM
SLITS   The sender is the variable ground for the guage. ...   Sep 14 2007, 07:46 AM
Cevan   Ahhhh, the metal tab on the black outer plate hold...   Sep 14 2007, 08:11 AM
Cevan   Someone wanted pictures of this procedure so here ...   Sep 15 2007, 11:12 AM
So.Cal.914   :clap:   Sep 15 2007, 12:35 PM
SirAndy   might not be ideal to route the wire through the h...   Sep 15 2007, 03:22 PM
Mike914   Guys, I think I posted pics of the wire routing in...   Sep 15 2007, 05:25 PM
Cevan   might not be ideal to route the wire through the ...   Sep 15 2007, 08:53 PM
Cevan   My oil temp gauge is a VDO but without the numbere...   Sep 18 2007, 03:17 PM
Grelber   That's about right. Mine runs between the ...   Sep 18 2007, 04:03 PM
- Lo-Fi Version Time is now: 16th June 2024 - 07:45 PM
