| Cevan |
Sep 20 2007, 12:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I searched around but couldn't find anything on replacing the instrument lights with LEDs. I bought a couple new instrument bulbs from Pelican, but the light was yellowish, not the white of the OEM lights. On the other hand, the OEM lights are not that bright (ok, they barely illuminate the gauge).
I found these that look like they would be a direct replacement (the BA-7 model). Has anyone tried them? |
| GeorgeRud |
Sep 20 2007, 09:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I swapped my guages to the LEDs a year ago, and they are OK. It's a whiter light, not yellow like the original bulbs. To my eyes, a bit easier to see at night.
However, in talking to the people at North Hollywood Speedo, their setup is much better, though much more expensive than simply replacing bulbs with LEDs. As usual, you get what you pay for. Also, be careful as there are higher wattage bulbs that will fit in the illumination holders. They get too hot and can melt/ burn out the instruments from what I've been told. |
Cevan Gauge lighting is dim. Sep 20 2007, 12:41 PM
RoninEclipse2G I would be interested to know as well, with the wi... Sep 20 2007, 12:46 PM
dinomium Check the member vendor area, Mike914 has a kit fo... Sep 20 2007, 12:57 PM
Cevan
Check the member vendor area, Mike914 has a kit f... Sep 20 2007, 01:10 PM
dinomium malibu barbie is right
Math is hard! Sep 20 2007, 01:24 PM
Bartlett 914 If I was looking at the correct LED, then the pric... Sep 20 2007, 01:39 PM
Cevan
If I was looking at the correct LED, then the pri... Sep 20 2007, 01:46 PM
jd74914 914s have a dimmer? Sep 20 2007, 03:16 PM
ConeDodger
914s have a dimmer?
Turn your headlight knob le... Sep 20 2007, 03:22 PM
jd74914
914s have a dimmer?
Turn your headlight knob l... Sep 20 2007, 04:32 PM
Demick Many of us (myself included) bought these from Qua... Sep 20 2007, 03:42 PM
lotus_65 i'm sure i'm different, but at night on lo... Sep 20 2007, 04:27 PM
SGB I got blue LEDs from Quarl a few years ago. I don... Sep 20 2007, 04:33 PM
iamchappy I got the blue in right now but also got some whit... Sep 20 2007, 05:02 PM
BarberDave :trophy:
I repolacede all my dash gauges ... Sep 20 2007, 05:11 PM
ConeDodger Red might be interesting to try, if available... ... Sep 20 2007, 05:12 PM
jd74914
Red might be interesting to try, if available... ... Sep 20 2007, 06:24 PM
Zaney I have Red LEDs in my gauge cluster and console. ... Sep 20 2007, 06:30 PM
orthobiz What about new, regular wattage incandescents. Is ... Sep 20 2007, 09:31 PM
ConeDodger
What about new, regular wattage incandescents. Is... Sep 20 2007, 10:09 PM
highways The other night I had just the parking lights and ... Sep 20 2007, 11:58 PM
rascobo For some reason every year the lights just get dim... Oct 5 2007, 10:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 10:07 PM |
