purple |
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None ![]() |
Hey Yall,
I just installed my Cylinder Head temp sensor under the plug on #3, didnt cut the wires and installed everything as per VDO specs. I also hooked up my oil temp gauge and to my delight, the sensor actually works. Now, the bad news... My engine runs hot....REAL hot. According to Jake, this thing should be severely damaged by now. At idle it'll get up to 350 on head temps pretty quick and stay there. After driving a little it'll get to 400 and stay there, going down to 350 when sitting at a light. If i start cruising at 45mph or so, it'll get to 400 and a little beyond, i think i've seen as high as 450 on there. Just cruising in 4th gear going 45 will do this. The thing is, the engine sounds fine. I was expecting to hear wierd noises or see smoke, but it just keeps thrumming along. What's going on here? About the engine: hydraulic lifters. no lower air diverter (plastic flap thingy) on passenger side no lower engine tin on driver's side pretty much shot seals around the engine tin no warm air guides stock 76 exhaust manifold to cobbled shitty motorcycle dual exhaust, 1 per cyl bank weber progressive carb what looks like a 009 on there (mallory and promaster are on the way) What can I do to lower these temps? is my engine toast? (it seems to drive just fine, if a little slow) It had run-on and was pinging on the last tank of gas (regular) but now i'm running premium and those things seem to have stopped Help me guys, jake, what can i do? timing? too lean? what? |
toon1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 ![]() |
thankfully i have the flaps. As I've read the flaps close off the oil cooler air until it's up to a certain temp. My oil takes quite a long time to heat up. I went after the tin with my HVAC speed tape and closed off everything. Question, it looks like there were holes on the side of the tin for the spark plugs. This means that it's not 2.0L tin, right? Thomas had some really hot converted tin that he needs to sell me (IMG:style_emoticons/default/wink.gif) Why is 2.0L tin so rare? are there advantages to running this stuff over 1.7L converted tin? TIN TIN TIN! Take some pics of what you are talking about. The reason 2.0 tin is rare is because everyone wants it. |
Lo-Fi Version | Time is now: 1st July 2025 - 06:19 AM |
