ot - i need subaru engine help, how to remove crank gear ?? |
jimkelly |
Sep 21 2007, 08:22 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i need to get the center gear of the crack so i can replace the keyway and dual belt pulley. thanks jim
pic http://www.pbase.com/jimkelly/image/85954997/original |
brer |
Sep 22 2007, 05:27 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
best of luck,
this part is ofter destroyed by being removed without the correct tool. I haven't done it, but i've seen alot of posts on the subaru forum with people bummed by wrecking it. maybe check out NASIOC forums? |
jimkelly |
Sep 22 2007, 08:22 PM
nasioc forum advice
There are two holes in the face of the sprocket. Tap those holes for 8x1.25mm and then use a puller to pull the sprocket off. Works every time By the way, sometimes those holes are prethreaded from the factory and sometimes they're not. -- best of luck, this part is ofter destroyed by being removed without the correct tool. I haven't done it, but i've seen alot of posts on the subaru forum with people bummed by wrecking it. maybe check out NASIOC forums? |
Lo-Fi Version | Time is now: 11th June 2024 - 10:53 AM |
