| watsonrx13 |
Sep 26 2007, 06:06 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Well, I've done some research on this site, but need some more information. I'm planning to replace the rear trunk floor and noticed McMark's comments on this post.
Here's what McMark suggested for replacing the trunk floor... ![]() In this picture I'm assuming that McMark cut the existing floor pan just in front of the center structure, then spot welded the replacement on top, like this? ![]() Also, I'm assuming that the sides and the rear section are spot welded to the sides, correct? Finally, my car has the original factory rear sway bars, I'm assuming I need to remove the sway bars, but how do I remove and reinstall the upper piece that is welded to the floor? ![]() -- Rob |
| dr914@autoatlanta.com |
Sep 28 2007, 11:31 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,231 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
usually we trim this to fit under the reinforcement and seam it there. Our nice piece that we make is shown in the picture. We made it that way for the bad cases when the floor would be rusted in front of the reinforcement. Again welding under the reinforcement is the best way. The pictures show an immaculate job, but they also show the replacement in the worst case scenario.
watsonrx13 Rear trunk floor replacement Sep 26 2007, 06:06 PM
dr914@autoatlanta.com We drill the spot welds out of the reinforcement s... Sep 27 2007, 10:57 AM
McMark I cut out the rear trunk piece just like you did. ... Sep 27 2007, 11:32 AM
watsonrx13 George and Mark, thank you very much for your sugg... Sep 27 2007, 07:38 PM
scotty b
George and Mark, thank you very much for your sug... Sep 28 2007, 07:38 PM
McMark Don't remove good metal just because it's ... Sep 28 2007, 12:39 PM
930cabman
Don't remove good metal just because it's... Aug 5 2023, 04:24 PM
Vacca Rabite Looks nicer then my rear trunk rust fix.
http://f... Sep 28 2007, 01:27 PM
davep Try to save the body number in that section of the... Sep 28 2007, 01:47 PM
watsonrx13
Try to save the body number in that section of th... Sep 28 2007, 06:21 PM
davep
Dave, I got this car with the rear trunk floor al... Sep 28 2007, 07:30 PM
zymurgist Looks better than Babydoll's (front) trunk fix... Sep 28 2007, 01:50 PM
watsonrx13
Looks better than Babydoll's (front) trunk fi... Sep 28 2007, 06:28 PM
watsonrx13 Thanks Scotty for replying... Can you post some pr... Sep 29 2007, 05:59 AM
scotty b
Thanks Scotty for replying... Can you post some p... Sep 30 2007, 07:53 AM
watsonrx13 Well, I've spent the entire weekend installing... Sep 30 2007, 05:31 PM
computers4kids Hi Rob!
Keep us posted how the trunk finally t... Oct 1 2007, 12:58 AM
watsonrx13 I painted the rear trunk with primer today....
... Oct 7 2007, 01:07 PM
URY914 Thread dug up from the past. :beer1: Aug 5 2023, 04:45 PM
930cabman
Yes, grea... Aug 5 2023, 05:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 06:10 AM |
