> Rear trunk floor replacement
watsonrx13
post Sep 26 2007, 06:06 PM
Well, I've done some research on this site, but need some more information. I'm planning to replace the rear trunk floor and noticed McMark's comments on this post.
Here's what McMark suggested for replacing the trunk floor...
In this picture I'm assuming that McMark cut the existing floor pan just in front of the center structure, then spot welded the replacement on top, like this?
Also, I'm assuming that the sides and the rear section are spot welded to the sides, correct?
Finally, my car has the original factory rear sway bars, I'm assuming I need to remove the sway bars, but how do I remove and reinstall the upper piece that is welded to the floor?
-- Rob
davep
post Sep 28 2007, 01:47 PM
914 Historian
Try to save the body number in that section of the trunk. In any event, be sure to update your car profile with that number so it is not lost.
watsonrx13
post Sep 28 2007, 06:21 PM
QUOTE(davep @ Sep 28 2007, 03:47 PM) *
Dave, I got this car with the rear trunk floor already removed, so I don't know the body number.
Zach, the PO provided the replacement piece with the purchase of the car.
Mark, I'm definately going to only cut out the sections that are bad. I'll post pics tomorrow showing how I fit the new piece. I've already cut out the passenger's side corner, but I left the metal where the sway bar bracket is welded. I'll be extra careful when I weld in the new piece. I agree, I'm not going to remove the cross member. I noticed that if I removed the cross member, I would still need to butt-weld the new piece beyond, so I've decided to do the butt-welding before it. Pics tomorrow will better show what I'm trying to describe...
George, this is the only pics I found on your web site showing the rear trunk floor replacement. It appears that there is a weld in front of the cross member, going the whole length of the replacement piece.
-- Rob
davep
post Sep 28 2007, 07:30 PM
914 Historian
QUOTE(watsonrx13 @ Sep 28 2007, 04:21 PM) *
It should still be on the Karmann badge on the drivers door hinge post. Check it out.
watsonrx13   Rear trunk floor replacement   Sep 26 2007, 06:06 PM
dr914@autoatlanta.com   We drill the spot welds out of the reinforcement s...   Sep 27 2007, 10:57 AM
McMark   I cut out the rear trunk piece just like you did. ...   Sep 27 2007, 11:32 AM
watsonrx13   George and Mark, thank you very much for your sugg...   Sep 27 2007, 07:38 PM
scotty b   George and Mark, thank you very much for your sug...   Sep 28 2007, 07:38 PM
dr914@autoatlanta.com   usually we trim this to fit under the reinforcemen...   Sep 28 2007, 11:31 AM
McMark   Don't remove good metal just because it's ...   Sep 28 2007, 12:39 PM
930cabman   Don't remove good metal just because it's...   Aug 5 2023, 04:24 PM
Vacca Rabite   Looks nicer then my rear trunk rust fix. http://f...   Sep 28 2007, 01:27 PM
davep   Try to save the body number in that section of the...   Sep 28 2007, 01:47 PM
watsonrx13   Try to save the body number in that section of th...   Sep 28 2007, 06:21 PM
davep   Dave, I got this car with the rear trunk floor al...   Sep 28 2007, 07:30 PM
zymurgist   Looks better than Babydoll's (front) trunk fix...   Sep 28 2007, 01:50 PM
watsonrx13   Looks better than Babydoll's (front) trunk fi...   Sep 28 2007, 06:28 PM
watsonrx13   Thanks Scotty for replying... Can you post some pr...   Sep 29 2007, 05:59 AM
scotty b   Thanks Scotty for replying... Can you post some p...   Sep 30 2007, 07:53 AM
watsonrx13   Well, I've spent the entire weekend installing...   Sep 30 2007, 05:31 PM
computers4kids   Hi Rob! Keep us posted how the trunk finally t...   Oct 1 2007, 12:58 AM
watsonrx13   I painted the rear trunk with primer today.... ...   Oct 7 2007, 01:07 PM
URY914   Thread dug up from the past. :beer1:   Aug 5 2023, 04:45 PM
930cabman   Thread dug up from the past. :beer1: Yes, grea...   Aug 5 2023, 05:43 PM
- Lo-Fi Version Time is now: 4th March 2026 - 06:12 AM
