> adjusting the shift linkage
mrhurtalot
post Sep 29 2007, 09:22 AM
VRRRRRRROOOOOOOOOM!
need as much info as possible, looked on pelicans, nothing, IPB searches dont ever work well on here! haha.
this is desperately urgent, this may be my last weekend to drive her. so today is a total work day for me. (IMG:style_emoticons/default/smile.gif) TIA (IMG:style_emoticons/default/welder.gif)
jd74914
post Oct 2 2007, 09:19 PM
Its alive
Purple, I wouldn't run the engine too much without anything on it. The exhaust reversion into the cylinders isn't cool. (IMG:style_emoticons/default/smile.gif)
mrhurtalot   adjusting the shift linkage   Sep 29 2007, 09:22 AM
So.Cal.914   Your Haynes manual has a good section on it, tails...   Sep 29 2007, 09:31 AM
rhodyguy   as paul asks, which flavor? what are the issues yo...   Sep 29 2007, 09:34 AM
mrhurtalot   the rod is just not the one that came with my car....   Sep 29 2007, 09:44 AM
So.Cal.914   If you don't have a haynes manual, try here; h...   Sep 29 2007, 10:09 AM
mrhurtalot   ive got it sitting right here in front of me, page...   Sep 29 2007, 10:10 AM
So.Cal.914   Sounds like your typical 'out of adjustment...   Sep 29 2007, 10:15 AM
mrhurtalot   okay now im out in the garage, carpets out, etc. i...   Sep 29 2007, 10:46 AM
joefri187   okay now im out in the garage, carpets out, etc. ...   Sep 29 2007, 03:30 PM
mrhurtalot   ohhhh under the little armrest box? i shouldve tho...   Sep 29 2007, 04:05 PM
mrhurtalot   okay, so ive checked in the little hole under the ...   Oct 2 2007, 12:21 AM
purple   you should have marked the rod and clamp at the bo...   Oct 2 2007, 07:03 AM
BMartin914   There is an access hole behind the shifter in the ...   Oct 2 2007, 08:38 AM
Dave_Darling   The idea is that you loosen (don't remove) the...   Oct 2 2007, 09:25 AM
SirAndy   The idea is that you loosen (don't remove) th...   Oct 2 2007, 01:03 PM
angerosa   I have to offer my two cents as well - Everyone is...   Oct 2 2007, 09:54 AM
mrhurtalot   ah. thats where i was confused, the haynes shows a...   Oct 2 2007, 01:30 PM
SLITS   ah. thats where i was confused, the haynes shows ...   Oct 2 2007, 01:56 PM
purple   You will look an ass trying to drag race in a 914....   Oct 2 2007, 01:33 PM
SirAndy   You will look an ass trying to drag race in a 914...   Oct 2 2007, 02:33 PM
cassidy_bolger   Don't forget to check your bushings. If they ...   Oct 2 2007, 02:06 PM
angerosa   Don't forget to check your bushings. If they...   Oct 2 2007, 04:13 PM
mrhurtalot   You will look an ass trying to drag race in a 914...   Oct 2 2007, 03:01 PM
purple   Check your tranny mounts... i have vague shifts an...   Oct 2 2007, 03:19 PM
rhodyguy   1. go under rear of car, remove clamp on large pla...   Oct 2 2007, 03:54 PM
So.Cal.914   I don't agree with you statement in whole, I...   Oct 2 2007, 05:28 PM
mrhurtalot   Check your tranny mounts... i have vague shifts a...   Oct 2 2007, 08:11 PM
purple   at present i have no exhaust...open valves to the ...   Oct 2 2007, 09:11 PM
jd74914   Purple, I wouldn't run the engine too much wit...   Oct 2 2007, 09:19 PM
mrhurtalot   so i spent about an hour working on this.. still c...   Oct 3 2007, 08:09 PM
drew365   After you disconnect the shifter from the rod, you...   Oct 3 2007, 09:38 PM
angerosa   After you disconnect the shifter from the rod, yo...   Oct 4 2007, 10:37 AM
drew365   After you disconnect the shifter from the rod, y...   Oct 4 2007, 05:47 PM
purple   I only started it up a couple times, i didnt let i...   Oct 3 2007, 10:01 PM
mrhurtalot   im excused from my next class at 230, and im free ...   Oct 4 2007, 01:34 PM
purple   clunking/rumbling? is that only when your foot is...   Oct 4 2007, 03:01 PM
mrhurtalot   so fellas, today, a dream was fullfilled, i was ...   Oct 4 2007, 11:56 PM
rhodyguy   what was the solution that worked? too tight in on...   Oct 5 2007, 10:24 AM
So.Cal.914   :)   Oct 5 2007, 02:25 PM
sendjonathanmail   :rotfl: -JON   Oct 5 2007, 04:20 PM
mrhurtalot   what was the solution that worked? too tight in o...   Oct 5 2007, 07:20 PM
mrhurtalot   oh lord, so tonight was that drive i was talking a...   Oct 7 2007, 03:43 AM
rhodyguy   so you showed him your tack didn't work. too f...   Oct 7 2007, 12:10 PM
mrhurtalot   its really not a problem, i dont live in yukon cur...   Oct 7 2007, 12:36 PM
jd74914   you don't wear a seatbelt :blink:   Oct 7 2007, 10:15 PM
mrhurtalot   pretty much, in oklahoma (for the most part) i cou...   Oct 8 2007, 12:31 PM
- Lo-Fi Version Time is now: 6th July 2025 - 01:32 PM
