> Gauge problem..., Oil pressure gauge skyrockets...
BMXerror
post Sep 30 2007, 12:04 AM
Okay, my new oil pressure gauge that I just wired up does something weird. When I turn ignition on it shoots all the way past the max reading (80 PSI). I can unplug the sensor wire from either the gauge or sensor side and the gauge stays pegged. If I unplug the ground on the gauge it drops to zero, and doesn't do anything when the engine's turned on (sensor plugged in). You would think it's hard to screw up such simple wiring, but I seem to have managed.
VDO gauge experts, the power lead comes from the fuse terminal to the + terminal on the gauge. The sensor wire is plugged into the 'S' terminal on the gauge. The ground is plugged in on the bottom terminal, which I'm assuming is the ground. That's what the diagram says, anyways. I'm using 16 gauge wire all around. (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/confused24.gif) Any help?
Mark D.
BMXerror
post Oct 3 2007, 09:01 PM
Any ideas on how to get that sensor to clear the tin and the dizzy?
Mark D.
- Lo-Fi Version Time is now: 3rd March 2026 - 04:47 PM
