> how to test alt, with this volt measuremometer ?
jimkelly
post Oct 4 2007, 09:34 AM
Delaware USA
and how to i test battery?
my car barely turns over when i turn the key but it always starts - but just barely.
is it my alternator, my battery, or my starter, or other ??
jim
SLITS
post Oct 4 2007, 02:11 PM
"This Utah shit is HARSH!"
If I am reading the scales correctly ... your battery voltage (not running) is 33 VDC and running it is 37 VDC .... so the alt is working.
However, I don't think your meter is set correctly. Does the indicator needle set on "0" when not connected to anything? If not, you have to zero the needle with the screw on the front face of the multimeter. It should read in the range of 12 VDC to 14 VDC (on the 50 scale) (assuming the voltage regulator is working correctly).
EDIT: If you zeroed the meter using the right hand zero you need to zero the meter using the left hand zero. Reading from right to left the readings would be 17 VDC at rest and 14 VDC running, which would indicate the alternator is not functioning.
To many problems here... the meter appears to be reading incorrectly ... I need an aspirin.
- Lo-Fi Version Time is now: 14th July 2025 - 03:13 AM
