| PinetreePorsche |
Oct 4 2007, 11:43 AM
Member ![]() ![]() Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 |
The first VWs (and Porsches) had dirty-air heat-- the 1950s sealed, 'fresh air' heater-box was a big step forward (and I patched many a Boston-area heater box on split-window vans in my relative youth), well before our Type IV motors came into being. I have a problem, enabling my dual carb-fitted (Webers; the p.o. did it-- it would not be my choice) 2.0 liter to mimic some of these earliest VWs: rapid build-up of dirty deposit on the windshield above the defrost vents and hydrocarbons in the pass. compartment air-- un-noticable in the warm weather, tolerable with the windows open, but a drag- and presumably a health risk- when the windows are up and the heater or esp. the defroster needed. The boxes are like new, and the joints all along the way are all snug. The problem is two different small breathers on the top of the engine, one a couple of inches (center to center) of the oil filler tower, the other about 3 1/2 inches toward the driver from the filler, which is one of three hoses running off a fitting, the other two of which disappear into the sheet metal of the cylinders-- one to each side. Both the short woven- cloth wrapped flexy- tubes coming up from these points are currently capped by what appear to be mini-air filters-- round, well over an inch in diameter and not much taller. Both display wire around their open circumference, possibly hiding other filtering material- can't tell.
SO, my Q's are: Are both these breather-like elements under positive pressure from the crankcase--suggested by the fact that a cleaned engine compartment will be well-bathed in oil after a modest run at near 100 mph-- and more gradually under more relaxed driving? IF so, is there a place on a carbed car for these to disgorge their effluents into a closed loop as in the original FI design. (Or is one positive pressure, the other neg? -which, if so?) Help me, Obi-wan Kenobi, or anyone else who knows how to channel the hydrocarbon force. |
| Cap'n Krusty |
Oct 4 2007, 02:47 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Run 'em into the air cleaners like nature (and the federal gummint) intended. Open crankcase breathers have been illegal in the USA since 1965. The Cap'n
PinetreePorsche 'Clean air" heat? Oct 4 2007, 11:43 AM
SLITS The valve covers run about 1/2 full of oil. The b... Oct 4 2007, 11:49 AM
SGB All those lines are under positive pressure due to... Oct 4 2007, 02:39 PM
PinetreePorsche
Run 'em into the air cleaners like nature (an... Oct 4 2007, 09:48 PM
pin31 I've got the same exact situation.......
:po... Oct 5 2007, 07:55 AM
rhodyguy you can find elcheapo plastic fittings with thread... Oct 5 2007, 10:18 AM
lotus_65
you can find elcheapo plastic fittings with threa... Oct 5 2007, 10:56 AM
Air_Cooled_Nut The T3 and T4 are very similar engine arrangements... Oct 5 2007, 12:39 PM
Jake Raby The key is removing the breather box from the area... Oct 5 2007, 01:00 PM
thomasotten From what I read on the old shoptalk forums, a set... Oct 5 2007, 03:04 PM
lotus_65 thanks, jake. i'd rather keep my trunk from ge... Oct 5 2007, 06:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 03:09 PM |
