> Welding Woes, to buy and learn / to hire a pro
stateofidleness
post Oct 5 2007, 10:10 AM
So im almost to the point where welding will be happening on the ol' floorpans
Im wondering whether it is worth the investment to buy a welder and all the accessories needed for the job (could be pricey i presume) or whether it's best just to hire a shop to weld up the holes in my floorpan?
if i DO buy a welder (which i think could be fun and a neat thing to learn), what am i looking for? i have a few small pencil diameter holes to patch and a couple baseball size holes to replace in the corners...
what type of welder should i look for?
what type of welding is best?
what type of metal to use?
where can i buy a cheap welder and acc. needed? (as cheap as possible! i dont mind used)
best to hire a pro?
this would be my first time welding so id probably practice on other things first, but im willing to learn and do it right. ive also got an engman kit on the way, so it would be nice to be able to weld that in myself!
Thanks for the help!
stateofidleness   Welding Woes   Oct 5 2007, 10:10 AM
TINCAN914   If it were up to me, I would buy the gear and lear...   Oct 5 2007, 10:13 AM
sgomes   Buy the welder. No brainer. Where you start is u...   Oct 5 2007, 10:24 AM
stateofidleness   is it a correct impression that MIG welders are mo...   Oct 5 2007, 10:26 AM
SLITS   Just bought a MIG .... Lincoln 215 .... about ...   Oct 5 2007, 10:32 AM
Vacca Rabite   Get a 120v 15Amp mig welder. They will run betwee...   Oct 5 2007, 10:35 AM
stateofidleness   WOW..wasnt expecting to spend that much... not any...   Oct 5 2007, 10:46 AM
iamchappy   This is a nice little welder for the price, can be...   Oct 5 2007, 10:51 AM
type11969   Buy the welder and do it yourself, in the end, you...   Oct 5 2007, 10:54 AM
Borderline   Figure you're going to spend roughly $500...   Oct 5 2007, 11:04 AM
angerosa   Figure you're going to spend roughly $50...   Oct 5 2007, 03:07 PM
thomasotten   You can get one for $350 plus $80 for a ...   Oct 5 2007, 11:19 AM
Travis Neff   I agree with Zach on a 110V model. that will do a...   Oct 5 2007, 11:36 AM
andys   +1 to what Zach said. Many argue to take it to th...   Oct 5 2007, 11:41 AM
Air_Cooled_Nut   Take a class in welding first. I learned first in...   Oct 5 2007, 12:03 PM
Chuck   I faced the same question about a month back: have...   Oct 5 2007, 12:56 PM
Vacca Rabite   Seriously. For ~$600 you can really be set u...   Oct 5 2007, 01:36 PM
Vacca Rabite   One more thing. Get an auto darkening helmet. mo...   Oct 5 2007, 01:38 PM
So.Cal.914   This isn't bad: http://www.weldingmart.com/Qs...   Oct 5 2007, 01:54 PM
Chuck   This isn't bad: http://www.weldingmart.com/Q...   Oct 5 2007, 03:27 PM
rjames   :agree: While not necessary, I took a 3 day c...   Oct 5 2007, 03:20 PM
Rick_Eberle   I had the same problem. Spring for the welder, and...   Oct 5 2007, 05:55 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:45 PM
