> Gauge lighting is dim., Has anyone tried these LED lights?
Cevan
post Sep 20 2007, 12:41 PM
I searched around but couldn't find anything on replacing the instrument lights with LEDs. I bought a couple new instrument bulbs from Pelican, but the light was yellowish, not the white of the OEM lights. On the other hand, the OEM lights are not that bright (ok, they barely illuminate the gauge).
I found these that look like they would be a direct replacement (the BA-7 model). Has anyone tried them?
rascobo
post Oct 5 2007, 10:01 PM
For some reason every year the lights just get dimmer(at least since I rounded 40).
I fixed dim gauges real good, drilled new holes where needed and installed mini halogens(+lgr ga. wire). At night oncoming traffic can count my liver spots.
Cevan   Gauge lighting is dim.   Sep 20 2007, 12:41 PM
RoninEclipse2G   I would be interested to know as well, with the wi...   Sep 20 2007, 12:46 PM
dinomium   Check the member vendor area, Mike914 has a kit fo...   Sep 20 2007, 12:57 PM
Cevan   Check the member vendor area, Mike914 has a kit f...   Sep 20 2007, 01:10 PM
dinomium   malibu barbie is right Math is hard!   Sep 20 2007, 01:24 PM
Bartlett 914   If I was looking at the correct LED, then the pric...   Sep 20 2007, 01:39 PM
Cevan   If I was looking at the correct LED, then the pri...   Sep 20 2007, 01:46 PM
jd74914   914s have a dimmer?   Sep 20 2007, 03:16 PM
ConeDodger   914s have a dimmer? Turn your headlight knob le...   Sep 20 2007, 03:22 PM
jd74914   914s have a dimmer? Turn your headlight knob l...   Sep 20 2007, 04:32 PM
Demick   Many of us (myself included) bought these from Qua...   Sep 20 2007, 03:42 PM
lotus_65   i'm sure i'm different, but at night on lo...   Sep 20 2007, 04:27 PM
SGB   I got blue LEDs from Quarl a few years ago. I don...   Sep 20 2007, 04:33 PM
iamchappy   I got the blue in right now but also got some whit...   Sep 20 2007, 05:02 PM
BarberDave   :trophy: \ I repolacede all my dash gauges ...   Sep 20 2007, 05:11 PM
ConeDodger   Red might be interesting to try, if available... ...   Sep 20 2007, 05:12 PM
jd74914   Red might be interesting to try, if available... ...   Sep 20 2007, 06:24 PM
Zaney   I have Red LEDs in my gauge cluster and console. ...   Sep 20 2007, 06:30 PM
GeorgeRud   I swapped my guages to the LEDs a year ago, and th...   Sep 20 2007, 09:01 PM
orthobiz   What about new, regular wattage incandescents. Is ...   Sep 20 2007, 09:31 PM
ConeDodger   What about new, regular wattage incandescents. Is...   Sep 20 2007, 10:09 PM
highways   The other night I had just the parking lights and ...   Sep 20 2007, 11:58 PM
rascobo   For some reason every year the lights just get dim...   Oct 5 2007, 10:01 PM
- Lo-Fi Version Time is now: 7th December 2025 - 10:09 PM
