| mdwman |
Oct 6 2007, 07:30 PM
Member ![]() ![]() Group: Members Posts: 65 Joined: 28-May 07 From: Tennessee Member No.: 7,764 |
After some bulb replacemts all the lights have been working fine on my '73 1.7. Then today my license plate lights and dash lights don't illuminate. The turn signal indicators, oil, brake, alt, and bright indicator work fine, just not the lights for the gauges. Checked the bulbs and fuses, what is the next step? Would the license and gauge lighting be connected?
| mdwman |
Oct 7 2007, 10:11 PM
Running lights work normally except for license lights. No luck jiggling the switch. I would check my connections to the swith but can't see how to get to it behind the dash. Do you have to remove the fuse block to get back there?
| BMartin914 |
Oct 7 2007, 10:52 PM
||| ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Running lights work normally except for license lights. No luck jiggling the switch. I would check my connections to the swith but can't see how to get to it behind the dash. Do you have to remove the fuse block to get back there? Unscrew the knob, then remove the escutcheon plate that threads into the dash face and you can remove the switch from the back. The fuse block does not need to be removed. |
mdwman Help Finding Gremlins In The Lights Oct 6 2007, 07:30 PM
SLITS I don't have my electrical diagrams in front o... Oct 7 2007, 09:23 AM
ClayPerrine The license lights are on a separate circuit from ... Oct 8 2007, 07:37 AM
mdwman Yup! Goes to show just because a fuse looks O... Oct 8 2007, 07:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 02:33 PM |
