| Jax914 |
Oct 8 2007, 09:57 AM
Schwienhund Rennenmannshaft ![]() ![]() Group: Members Posts: 138 Joined: 7-August 06 From: Jacksonville, FL Member No.: 6,602 Region Association: South East States |
Okay,
I'm looking for some ideas.... I have a 1971 1.7 - stock heat exchangers, manta exhaust. I've replaced the copper gaskets between the heat exchanger and the head, applied what I think is way too much torque to the exhaust nuts and can't get it to stop leaking. I removed the exchanger and made sure the top of the flange is level and smooth. When I start it up and crawl under, I can feel the leak. My thoughts are to try running two gaskets?!? Anyone else have similar problems? TIA, |
| rhodyguy |
Oct 8 2007, 10:27 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
if you went thru the torqueing sequence and ran them up fully as you put them on, you may have cocked the he's with a built in leak. did you lightly pass a big wide file over the tops of the pipes, one side, both pipes at one time? try just loosening all 4 nuts so the he is just free. press it up so you can feel full contact and no rocking of the he. with you free hand take the torque up in a few passes. just reefing down on the nuts trying to cure the leak could be disasterous. be careful.
Jax914 Leaking exhaust at head... Oct 8 2007, 09:57 AM
Bartlett 914 The ears on the HE pipes may be hitting the boss f... Oct 8 2007, 10:14 AM
HAM Inc Because the studs are outside of the sealing flang... Oct 8 2007, 11:27 AM
rhodyguy forgot to add, make SURE all the rings are out... Oct 8 2007, 11:34 AM
KaptKaos I was installing mine this weekend. I just want t... Oct 8 2007, 11:38 AM
Dan (Almaden Valley)
I was installing mine this weekend. I just want ... Oct 8 2007, 11:39 AM
rjames
Mind Kevin on this one!! Oct 8 2007, 08:17 PM
BMartin914 Torque exhaust nuts to 18 ft/lbs. More and you ris... Oct 8 2007, 09:39 PM
KaptKaos
Torque exhaust nuts to 18 ft/lbs. More and you ri... Oct 8 2007, 10:09 PM
davep Len did not mention it, but he has commented in th... Oct 8 2007, 10:10 PM
Cap'n Krusty Begin with the assumption that double gaskets NEVE... Oct 8 2007, 11:25 PM
jk76.914 If you haven't seen this already.... I tried ... Oct 9 2007, 05:09 AM
Jax914 thanks everyone....hopefully I'll have some ti... Oct 9 2007, 06:55 AM
jk76.914 Be careful on the torque. I'd say 18 ft-lbs i... Oct 9 2007, 05:54 PM
ChrisNPDrider My system for almost all repairs is to tighten, dr... Oct 9 2007, 07:20 PM
Jax914 Haven't done anything yet....but to answer - y... Oct 9 2007, 08:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 07:44 AM |
