> shift rod to engine bar clearance problems, tailshift to sideshift conversion
mightyohm
post Oct 8 2007, 08:26 PM
My car is a 72 with a sideshift conversion (done long before I bought the car). The engine mount bar originally had the ends chopped down to raise the motor, apparently so that the shift rod would clear the bar in 4th/5th gear. I need to lower the motor to get my 2.0L airbox to fit, so I am putting in a stock engine mount bar, and now the shift rod rubs a little bit when I try to shift into 4th or 5th.
Do the tailshift cars have the shift rod up higher on the firewall than sideshift cars? I had never heard that before but bondo says he thinks he has heard of this issue before. I can't imagine that I am the only person to run into this clearance issue if this is true.
I managed to bend the rod a bit by pulling down on it but I'd like to get a little more clearance. I'm not sure how easy it will be to bend the shift rod more without making a jig to keep the ends in the right alignment. Has anyone done this before?
Brando
post Oct 8 2007, 08:39 PM
BUY MY SPARE KIDNEY!!!
Did you get a side-shift engine bar? they are significantly different between side-shift and tail-shift bars.
mightyohm
post Oct 8 2007, 09:02 PM
QUOTE(Brando @ Oct 8 2007, 07:39 PM) *
Both bars are definitely sideshift.
- Lo-Fi Version Time is now: 14th April 2026 - 06:16 PM
