| Jax914 |
Oct 8 2007, 09:57 AM
Schwienhund Rennenmannshaft ![]() ![]() Group: Members Posts: 138 Joined: 7-August 06 From: Jacksonville, FL Member No.: 6,602 Region Association: South East States |
Okay,
I'm looking for some ideas.... I have a 1971 1.7 - stock heat exchangers, manta exhaust. I've replaced the copper gaskets between the heat exchanger and the head, applied what I think is way too much torque to the exhaust nuts and can't get it to stop leaking. I removed the exchanger and made sure the top of the flange is level and smooth. When I start it up and crawl under, I can feel the leak. My thoughts are to try running two gaskets?!? Anyone else have similar problems? TIA, |
| jk76.914 |
Oct 9 2007, 05:09 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
If you haven't seen this already.... I tried it on mine, and it works. The copper rings are definitely softer, you can tell if you slightly bend them (warp them really) by hand....
http://www.ratwell.com/technical/Exhaust.html |
Jax914 Leaking exhaust at head... Oct 8 2007, 09:57 AM
Bartlett 914 The ears on the HE pipes may be hitting the boss f... Oct 8 2007, 10:14 AM
rhodyguy if you went thru the torqueing sequence and ran th... Oct 8 2007, 10:27 AM
HAM Inc Because the studs are outside of the sealing flang... Oct 8 2007, 11:27 AM
rhodyguy forgot to add, make SURE all the rings are out... Oct 8 2007, 11:34 AM
KaptKaos I was installing mine this weekend. I just want t... Oct 8 2007, 11:38 AM
Dan (Almaden Valley)
I was installing mine this weekend. I just want ... Oct 8 2007, 11:39 AM
rjames
Mind Kevin on this one!! Oct 8 2007, 08:17 PM
BMartin914 Torque exhaust nuts to 18 ft/lbs. More and you ris... Oct 8 2007, 09:39 PM
KaptKaos
Torque exhaust nuts to 18 ft/lbs. More and you ri... Oct 8 2007, 10:09 PM
davep Len did not mention it, but he has commented in th... Oct 8 2007, 10:10 PM
Cap'n Krusty Begin with the assumption that double gaskets NEVE... Oct 8 2007, 11:25 PM
Jax914 thanks everyone....hopefully I'll have some ti... Oct 9 2007, 06:55 AM
jk76.914 Be careful on the torque. I'd say 18 ft-lbs i... Oct 9 2007, 05:54 PM
ChrisNPDrider My system for almost all repairs is to tighten, dr... Oct 9 2007, 07:20 PM
Jax914 Haven't done anything yet....but to answer - y... Oct 9 2007, 08:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 07:44 AM |
