| 73Phoenix20 |
Oct 9 2007, 11:35 AM
Member ![]() ![]() Group: Members Posts: 334 Joined: 15-June 05 From: Michiana Member No.: 4,283 |
I know some of you folks will have some advise for me on this subject...
I need answers to several questions regarding media blasting... 1. Is the 'Pressure Pot" Blast System significantly superior to the gravity fed system? I can get either one at Harbor Freight (and prolly other places) for about $50.00 difference, which is trivial, IF the Pressure Pot system really works better... 2. I can get Aluminum Oxide media for $40 per 25lb box... how much surface area will this cover, assuming I am removing the factory paint down to bare sheetmetal? 5 square feet? 10 square feet? More? For an easy example, will 25 lbs strip the hood of a 914? Or maybe the hood and trunk (top surface only)? 3. I can get crushed walnut shells for about $20.00 per box, but i assume they are much less effective? How much less? Will it take twice as much in walnut shells vs. aluminum oxide? 4. Luckily, I only need to strip the exterior, as the interior is in fantastic shape, and I am repainting to original color. What is the best material to use to mask areas that I don't want to get "accidentally" blasted? Heavy duct tape? Multiple layers of heavy plastic sheeting? 5. Will Aluminum Oxide risk warping of the sheet metal due to heating? I understand walnut shells won't warp panels? True or not? If they are only marginally less effective, and half the price, I guess I will go with the walnut shells? Prolly more, but that is all I can think of right now! Thanks folks! |
| rhodyguy |
Oct 9 2007, 01:31 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
that compressor rental is a good idea. you know you're never going to have to stop blasting and wait on the compressor to catch up. repeatedly. i bet a car could be done in a day or less. it will go pretty fast. invest in a canister/element breather. not a particle mask. mask any areas off with heavy pastic and duct tape to keep the bulk of mess out.
73Phoenix20 The Cost of "DIY" Media Blasting... Oct 9 2007, 11:35 AM
Travis Neff Aluminum oxide is VERY aggressive, get ready for a... Oct 9 2007, 11:45 AM
rhodyguy if you don't have one, the biggest exspence wi... Oct 9 2007, 12:11 PM
Brian Mifsud When you are ready to media blast, rent a monster ... Oct 9 2007, 01:11 PM
73Phoenix20 I'm running a 1.5 HP Compressor on a 250 Gallo... Oct 9 2007, 01:19 PM
Vacca Rabite If you trap the media, you can generally run it th... Oct 9 2007, 01:24 PM
Brian Mifsud Baking soda is a "salt", so you should b... Oct 9 2007, 01:33 PM
73Phoenix20 Hmmm... I like the BIG Rental Compressor idea, and... Oct 9 2007, 01:45 PM
rhodyguy with the huge volume you can move up to a presure ... Oct 9 2007, 01:53 PM
Richard Casto I am going through this right now. I had initially... Oct 9 2007, 04:23 PM
Wilhelm I have generally had better success with pressure ... Oct 9 2007, 05:20 PM
73Phoenix20 Hey, all great info! I will definitely want t... Oct 9 2007, 06:30 PM
majkos :popcorn: Yeah! Keep them coming! :headban... Oct 9 2007, 06:42 PM
scotty b FYI soda blasting requires a completely different ... Oct 9 2007, 07:13 PM
73Phoenix20 I'm thinking of getting one or two of those di... Oct 9 2007, 08:46 PM
Jeff Hail Easy home blasting method:
If you have one of thos... Oct 9 2007, 10:03 PM
73Phoenix20 A Canopy! Great idea! I bought one a cou... Oct 10 2007, 08:23 AM
Krieger914 We used to blast the airframes of B-25's with ... Oct 10 2007, 10:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th March 2026 - 06:01 PM |
