Mallory Install Part 3--No spark |
jaybird840 |
Oct 9 2007, 10:08 AM
Member Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
OK,
On to phase three of the Unilite install. I got the dizzy drive properly indexed and the dizzy set at TDC on #1. I verified by thumb-over-hole and by watching the valves. Now I am getting no spark out of the dizzy. Car ran on 009 dizzy two days ago. Replaced coil with new Bosch blue and installed the Unilite. I have checked and replaced all of the spade terminal ends, so I should have good contacts. From the Unilite, I have the brown wire to engine block ground, the green wire to coil neg (I assume that's the one with the minus sign), and red wire to coil positive (the one marked "15"). I say no spark, because I am getting no flash from a timing light (which worked two days ago, and shows to have power--it's digital). Attached is a pic of the coil. Let me know where to go from here.... |
Jake Raby |
Oct 10 2007, 04:50 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Will trade for firearms!!!!
Thats my other hobby! |
jaybird840 |
Oct 10 2007, 05:10 PM
Will trade for firearms!!!! Thats my other hobby! Well.... we might have to do something about that. I'll shoot you a PM after I've assessed what I can live without in the gun safe. (IMG:style_emoticons/default/ar15.gif) Thanks tons for the free advice. (IMG:style_emoticons/default/pray.gif) Both the timing and the mechanic were retarded (mechanic still is... (IMG:style_emoticons/default/av-943.gif) ). Set it to 28 deg at 3500, and it runs like a champ now. My Dells even quit farting! Last, if you feel compelled to dish out even more free advice (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) , what kinda plug gap do you recommend? Stock 1.8 w/ 40 dells + bursch header/exhaust. I gapped them at 0.040".... Now that it's all lined out, I can go back and clean up the wiring install to make it tidy.... Jake Raby, you ROCK!! (IMG:style_emoticons/default/aktion035.gif) --Jaybird |
Lo-Fi Version | Time is now: 10th June 2024 - 02:32 PM |
