Rear wing project COMPLETED with pics, I ran it for the first time Sunday |
URY914 |
Aug 15 2007, 08:41 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I can't leave well enough alone. It's 66" wide, 52" from the ground to the top. I cut some masonite supports which will be 1/8" aluminum, and used a piece of cardboard for an end plate. I haven't decided on end plate material, could be CF, FG, lexan, aluminum, whatever.
Attached thumbnail(s) |
Chris Pincetich |
Oct 11 2007, 01:49 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Sweet! (IMG:style_emoticons/default/beerchug.gif)
I hope those flat braces are strong enough. I guess you could estimate whatever lbs downforce at 65 mph, then stack some weights on them while mocked up and see how stable it is. What type of resin did you choose for the carbon fiber piece, polyester or epoxy? |
Lo-Fi Version | Time is now: 11th June 2024 - 01:07 AM |
