WOT: VW Jetta problem |
ruddyboys |
Oct 12 2007, 10:34 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I have a 2003 Jetta 2.0l. Started the car the otherday and the car idled very rough, I noticed the check engine light was blinking and kept blinking for about 3 minutes and stayed on (oh by the way the check engine light has been on for about a month need to replace the O2 sensor) As I started to drive the car it was bucking and had no power, hills I drove up in 5th gear I had to down shift to 4th. Also I noticed I am getting interference on the radio, It radio noise doesn't speed up as the car goes faster just a constant sort of thumping static.
jonferns |
Oct 12 2007, 01:26 PM
Advanced Member Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States |
You should check out GAP, they carry all the OEM stuff for your jetta at decent prices. Germanautoparts.com (IMG:style_emoticons/default/bye1.gif)
911quest |
Oct 12 2007, 04:17 PM
Member Group: Members Posts: 277 Joined: 26-March 06 From: Louisville Ky Member No.: 5,773 Region Association: South East States |
Do the old spray bottle trick get you a bottle fill with water and spray dow the coil and the plug wires the coil on this car is under the seconday air pump so it is a pain to see. But you will probaly start to hear it arching
Lo-Fi Version | Time is now: 10th June 2024 - 11:43 AM |
