Bleeding Spongy Brakes, Proportioning Valve Questions |
Cjllong |
Oct 14 2007, 11:04 PM
Member Group: Members Posts: 66 Joined: 2-July 07 From: Ukiah Member No.: 7,862 |
I did a rear brake pad replacement. After putting everything back together and bleeding the brakes, I still had spongy brakes. I inspected the old rubber lines and found a leak. I bought 4 steel braided brake lines and intalled them all today. I re-bled the brakes, using the family member method mentioned on Pelican Parts, and STILL have spongy brakes! (IMG:style_emoticons/default/headbang.gif) I have double checked everything and nothing leaks. The Pel. Parts article mentions bleeding the proportioning valve, but it's not very clear to me as to how it's done. Does anybody have any pics of this valve and how to bleed it correctly? I believe I still have the 17mm master cylinder and I think I'm going to have to buy the 19mm. I just have to do it secrectly, so my wife doesn't find out!! Thanks!
davep |
Oct 16 2007, 09:18 AM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Make the correction in your Haynes manual in ink. The Cap'n is a dealer trained mechanic, and got the info direct from the factory instructors. This is one bit of false info that got out and was never properly corrected.
Lo-Fi Version | Time is now: 8th June 2024 - 08:51 PM |
