| roadster fan |
Oct 19 2007, 08:19 PM
Project Frankenstein !!!!!!!! ![]() ![]() ![]() Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
Hope someone can help (Eric Shea? are you out there?). I rebuilt the rear calipers on my 71, and went to adjust the venting clearance on the right side and ran into a problem. The adjuster on the outside half just spins without pushing out the piston. I am guessing I assembled it incorrectly but when putting it back together I swear everything was working (2 weeks ago), now it just spins. (IMG:style_emoticons/default/mad.gif)
Hope someone comes up with easy solution, or else tomorrow off it comes and I will tear it apart and check it out. Oh, by the way, thanks Eric Shea for the rebuild write up in the Classic Forum, could not have done it without you. Jim |
| porsche914gt |
Oct 19 2007, 09:36 PM
Member ![]() ![]() Group: Members Posts: 87 Joined: 20-January 04 From: Los Angeles, CA Member No.: 1,581 Region Association: None
Sounds like you dont have the "C" clip on outer threads. Without that it will just spin and go nowhere.
roadster fan I rebuilt the rear calipers but........ Oct 19 2007, 08:19 PM
davep I assume you are turning it in the correct directi... Oct 19 2007, 09:18 PM
roadster fan
I assume you are turning it in the correct direct... Oct 20 2007, 01:36 AM
swl sounds familiar.
http://www.914world.com/bbs2/ind... Oct 19 2007, 09:21 PM
davep a parts breakdown of the external adjuster Oct 20 2007, 09:48 AM
davep note the position of the circlip in the mechanism,... Oct 20 2007, 09:54 AM
roadster fan Thanks for the pics davep. I will have check and ... Oct 20 2007, 01:17 PM
Eric_Shea
LOL I have one of those on my bench as well :rot... Oct 21 2007, 12:50 AM
roadster fan Eric,
You rule! :worship: The air wrench... Oct 21 2007, 02:18 AM
Eric_Shea Way happy that it worked for ya! ;) Oct 21 2007, 10:14 AM
davep There is nothing to stop the adjuster from spinnin... Oct 21 2007, 11:23 AM
Eric_Shea Yup.
I never grease that assembly. I do however ... Oct 21 2007, 11:48 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2026 - 06:53 PM |
