| roadster fan |
Oct 19 2007, 08:19 PM
Project Frankenstein !!!!!!!! ![]() ![]() ![]() Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
Hope someone can help (Eric Shea? are you out there?). I rebuilt the rear calipers on my 71, and went to adjust the venting clearance on the right side and ran into a problem. The adjuster on the outside half just spins without pushing out the piston. I am guessing I assembled it incorrectly but when putting it back together I swear everything was working (2 weeks ago), now it just spins. (IMG:style_emoticons/default/mad.gif)
Hope someone comes up with easy solution, or else tomorrow off it comes and I will tear it apart and check it out. Oh, by the way, thanks Eric Shea for the rebuild write up in the Classic Forum, could not have done it without you. Jim |
| davep |
Oct 19 2007, 09:18 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,381 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I assume you are turning it in the correct direction.
Does it spin easily or with significant effort? Did you reassemble the internal mechanism correctly and get it seated in the groove? If it is not seated in the groove then you have to adjust it until you hear it snap into place. With some effort you can get the whole assembly to spin within the piston, but if so, I'd have to say you did not do the rebuild correctly. Both Eric and I put a lot of effort into the rebuilds so that the customer does not have these problems. Lots of custom tools and trick required, and tons of experience. Even then it is not a trivial matter. Each caliper takes hours to disassemble, clean, and reassemble. |
| roadster fan |
Oct 20 2007, 01:36 AM
I assume you are turning it in the correct direction. Does it spin easily or with significant effort? Did you reassemble the internal mechanism correctly and get it seated in the groove? If it is not seated in the groove then you have to adjust it until you hear it snap into place. With some effort you can get the whole assembly to spin within the piston, but if so, I'd have to say you did not do the rebuild correctly. Both Eric and I put a lot of effort into the rebuilds so that the customer does not have these problems. Lots of custom tools and trick required, and tons of experience. Even then it is not a trivial matter. Each caliper takes hours to disassemble, clean, and reassemble. It spins easily in both directions after the lock nut is loosened. The inner piston is working but not the outer. When you say 'internal mechanism' you are talking about the adjusting screw? Is it possible to have the piston too far into the bore to the point the adjusting screw won't "catch" the piston to adjust it out? And the c-clip is installed. It's not the end of the world to disassemble it tomorrow, FWIW the left side works great after the rebuild. I can now appreciate how much time you guys put into rebuilding them, and for the price you charge I don't know how you make any $$ (IMG:style_emoticons/default/pray.gif) . It was a rewarding project though, I guess I will have to have a second go at the right rear if there is no more wisdom. Thanks to all, keep the ideas coming! Jim |
roadster fan I rebuilt the rear calipers but........ Oct 19 2007, 08:19 PM
swl sounds familiar.
http://www.914world.com/bbs2/ind... Oct 19 2007, 09:21 PM
porsche914gt Sounds like you dont have the "C" clip o... Oct 19 2007, 09:36 PM
davep a parts breakdown of the external adjuster Oct 20 2007, 09:48 AM
davep note the position of the circlip in the mechanism,... Oct 20 2007, 09:54 AM
roadster fan Thanks for the pics davep. I will have check and ... Oct 20 2007, 01:17 PM
Eric_Shea
LOL I have one of those on my bench as well :rot... Oct 21 2007, 12:50 AM
roadster fan Eric,
You rule! :worship: The air wrench... Oct 21 2007, 02:18 AM
Eric_Shea Way happy that it worked for ya! ;) Oct 21 2007, 10:14 AM
davep There is nothing to stop the adjuster from spinnin... Oct 21 2007, 11:23 AM
Eric_Shea Yup.
I never grease that assembly. I do however ... Oct 21 2007, 11:48 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2026 - 06:53 PM |
