| minnesota loon |
Oct 19 2007, 08:20 AM
Member ![]() ![]() Group: Members Posts: 111 Joined: 30-September 07 From: white bear lake mn. Member No.: 8,173 |
Has anyone gone to a ram air system? It would seem to open up alot of space in the engine compartment. What has your experience been? Is it worth the investment?
| JPB |
Oct 21 2007, 08:38 AM
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
The most important thing about air intake is the temperature of the air. Cooler air is denser than hot air. If you get your air from outside the engine compartment, you will get a minute differencs, I think Jake might have said like up to 5HPs or sumtin. The trick if you want a real noticable difference is to add a watery mist or fog into the intake. If you ever drive on a really misty evening, you will get what I mean. The engine seems to pack more energy. If the air intake is warm and foggy full of water vapor, then you will get a diffrence you will feel. The water vapour must not condensate on its way into the engine though, this will add droplets of water into your air/fuel mixture. It would be cool to adapt a water evaporator on the exhaust pipes some how and then have conduits that plumb directly into the intake above the carb/throttle body. Since water vapor rises, the mist could find it's way into the intake easily. It could also be designed so that any condensation could drip right back down to the evaporator again. Crap I might be onto something here! (IMG:style_emoticons/default/beer.gif)
minnesota loon ram air Oct 19 2007, 08:20 AM
rick 918-S Need more info. Are you speaking of cooling or eng... Oct 19 2007, 08:37 AM
minnesota loon Engine intake air. auto atlanta has a system for s... Oct 19 2007, 08:54 AM
tdgray Not worth it... couple of guys have done it with m... Oct 19 2007, 10:21 AM
ChrisNPDrider I built this below for my 1.7....GREEN racing filt... Oct 19 2007, 12:00 PM
BahnBrenner914 I have the Autoatlanta type intake. It's not a... Oct 19 2007, 06:30 PM
Cap'n Krusty
I have the Autoatlanta type intake. It's not ... Oct 19 2007, 07:26 PM
Maltese Falcon
The changeover to a cone style filter has its up... Oct 19 2007, 10:55 PM
Maltese Falcon
Turbo engines benefit even more from the cone fi... Oct 19 2007, 11:10 PM
nein14
Turbo engines benefit even more from the cone f... Oct 23 2007, 08:21 AM
Maltese Falcon
...the cold air attachment for the turbo 335i. C... Oct 19 2007, 11:15 PM
Brando To get ram air you'd have to run ducting to th... Oct 20 2007, 01:43 AM
Mid_Engine_914 Cold Air Intakes definitely work on modern cars. I... Oct 20 2007, 09:25 AM
BarberDave :trophy:
There is a guy in Texas, Charlie Davis... Oct 21 2007, 04:33 AM
jd74914 Water injection is evil, don't try it unless y... Oct 21 2007, 08:21 PM
Cevan What about simply rerouting the air intake pipe co... Oct 22 2007, 11:07 AM
Dave_Darling
What about simply rerouting the air intake pipe c... Oct 23 2007, 02:16 AM
Joe Ricard When the engine is running the air on top of the e... Oct 22 2007, 12:20 PM
Maltese Falcon A downpour of rain onto the cone air filter is als... Oct 23 2007, 02:34 AM
blitZ I agree with Marty, make sure you get a quality fi... Oct 23 2007, 08:31 AM
Maltese Falcon ...nein14...the cone filter (#VC001) just by itsel... Oct 23 2007, 09:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:37 PM |
