> Carbs and Emissions. I failed, high HC, What can I do?
newto914s
post Oct 26 2007, 01:29 PM
I'm trying to sell a 73 Fastback I have. The buyer wanted me to get it e-checked, I was reluctant, but need this car gone. I brought it in this morning and it failed. Which surprised me cause it runs really good.
It is not FI anymore
Dual baby Webbers (I-34) on a stock 1600 DP
It had high HC at idle, 1223 and 1000 is the limit. Apparently HC are the result of unburned gas. At 2500 rpms it was within the limit, 734 out of 1000.
Could this be something simple, syncing the carbs, adjusting the timing, I have nether the time, nor desire to F with this car.
Could I just crank up the timing and run some of the e-check additives and maybe squeeze by.
Or maybe lean out the carbs a bunch, and which screw would do that?
Help I just want to wash my hands of this car.
Samson
Cap'n Krusty
post Oct 26 2007, 02:31 PM
Cap'n Krusty
Welcome to Weber World. Here's some hints, things that have worked for me (and I deal with this all the time). Set the valves at .016". DO NOT ADVANCE THE TIMING! That'll make it even worse! Make sure the vacuum retard works, if it has one. (I think '73 did.) Run REGULAR grade fuel. If it has any other fuel in it, drain it out and replace it. It might help to properly synch the carbs and adjust the mixture, but you need to do all the things I listed to ensure the best possible chance of it's passing. The Cap'n
newto914s   Carbs and Emissions. I failed, high HC   Oct 26 2007, 01:29 PM
blitZ   Seems like leaning it out a bit would work to pass...   Oct 26 2007, 02:25 PM
angerosa   Seems like leaning it out a bit would work to pas...   Oct 26 2007, 05:56 PM
orange914   Seems like leaning it out a bit would work to pas...   Oct 26 2007, 06:02 PM
Cap'n Krusty   Welcome to Weber World. Here's some hints, th...   Oct 26 2007, 02:31 PM
Jeffs9146   Sell it in California.....Exempt here!   Oct 26 2007, 02:35 PM
newto914s   Sell it in California.....Exempt here! Dude,...   Oct 26 2007, 03:56 PM
Thack   Lean it out by using some ethanol. One gallon etha...   Oct 26 2007, 04:00 PM
Zundfolge   Thank God El Paso County CO opted out of the AIR p...   Oct 26 2007, 05:39 PM
BMartin914   (or tell the buyer he'll have to do that ... ...   Oct 27 2007, 11:24 AM
Zundfolge   Actually, it's Samson's responsibility as...   Oct 27 2007, 07:31 PM
drive-ability   Retard the timing (base timing), maybe 4 degrees. ...   Oct 26 2007, 06:12 PM
Gint   :agree: Ben is right. The seller is legally obl...   Oct 27 2007, 12:03 PM
Gint   Run the car around for 20 minutes and get it good ...   Oct 28 2007, 10:19 AM
Aaron Cox   get a CDI box :) 100 bucks. Multiple spark, hotte...   Oct 27 2007, 12:07 PM
Gint   Spend $100 on a car he's trying to get ri...   Oct 27 2007, 12:38 PM
Aaron Cox   Spend $100 on a car he's trying to get r...   Oct 27 2007, 07:45 PM
rhodyguy   thesamba   Oct 28 2007, 07:11 AM
rhodyguy   what do you need to see for your fasty? can you po...   Oct 28 2007, 11:00 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:26 PM
