| newto914s |
Oct 26 2007, 01:29 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 |
I'm trying to sell a 73 Fastback I have. The buyer wanted me to get it e-checked, I was reluctant, but need this car gone. I brought it in this morning and it failed. Which surprised me cause it runs really good.
It is not FI anymore Dual baby Webbers (I-34) on a stock 1600 DP It had high HC at idle, 1223 and 1000 is the limit. Apparently HC are the result of unburned gas. At 2500 rpms it was within the limit, 734 out of 1000. Could this be something simple, syncing the carbs, adjusting the timing, I have nether the time, nor desire to F with this car. Could I just crank up the timing and run some of the e-check additives and maybe squeeze by. Or maybe lean out the carbs a bunch, and which screw would do that? Help I just want to wash my hands of this car. Samson |
| Aaron Cox |
Oct 27 2007, 12:07 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
get a CDI box (IMG:style_emoticons/default/smile.gif)
100 bucks. Multiple spark, hotter spark (if you swap the coil out) = cleaner burn, better idle, and more power (IMG:style_emoticons/default/smile.gif) easiest way i know of to clean it up (IMG:style_emoticons/default/smile.gif) |
newto914s Carbs and Emissions. I failed, high HC Oct 26 2007, 01:29 PM
blitZ Seems like leaning it out a bit would work to pass... Oct 26 2007, 02:25 PM
angerosa
Seems like leaning it out a bit would work to pas... Oct 26 2007, 05:56 PM
orange914
Seems like leaning it out a bit would work to pas... Oct 26 2007, 06:02 PM
Cap'n Krusty Welcome to Weber World. Here's some hints, th... Oct 26 2007, 02:31 PM
Jeffs9146 Sell it in California.....Exempt here! Oct 26 2007, 02:35 PM
newto914s
Dude,... Oct 26 2007, 03:56 PM
Thack Lean it out by using some ethanol. One gallon etha... Oct 26 2007, 04:00 PM
Zundfolge Thank God El Paso County CO opted out of the AIR p... Oct 26 2007, 05:39 PM
BMartin914
(or tell the buyer he'll have to do that ... ... Oct 27 2007, 11:24 AM
Zundfolge
Actually, it's Samson's responsibility as... Oct 27 2007, 07:31 PM
drive-ability Retard the timing (base timing), maybe 4 degrees. ... Oct 26 2007, 06:12 PM
Gint :agree:
Ben is right. The seller is legally obl... Oct 27 2007, 12:03 PM
Gint Run the car around for 20 minutes and get it good ... Oct 28 2007, 10:19 AM
Gint Spend $100 on a car he's trying to get ri... Oct 27 2007, 12:38 PM
Aaron Cox
Spend $100 on a car he's trying to get r... Oct 27 2007, 07:45 PM
rhodyguy thesamba Oct 28 2007, 07:11 AM
rhodyguy what do you need to see for your fasty? can you po... Oct 28 2007, 11:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:26 PM |
