Replaced some wheel bearings this weekend, How are yours? |
Rand |
Oct 28 2007, 08:15 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I know there are some of you out there who have never checked your wheel bearings. I recommend doing it. (IMG:style_emoticons/default/smile.gif)
I figured it was time to check mine. So, I jacked up a front corner to get a wheel off the ground. Grabbed the wheel and rocked it back and forth to feel for any slop. Drivers side good. Tried passenger side.... HOLY COW! WAY loose! Tried tightening up the nut a bit to see of the slack came out... No! Something's wrong. Removed the wheel. Removed the caliper. (A small rubber cork works perfect for plugging the line BTW.) Wow, that hub/disk was sloppy! Took it apart and found... Outer bearing toasted! Retainer shot and loose bearings inside! Outsch. The race on the bad bearing was also badly pitted. The inner race and bearings were fine, but my FLAPS had them all in stock and cheap - so I went ahead and replaced them all. My son enjoyed helping pack the grease and working the brake pedal at bleeding time. It's a cheap and easy job, so you might want to check yours out. (IMG:style_emoticons/default/smile.gif) |
scruz914 |
Oct 30 2007, 12:03 AM
Senior Member Group: Members Posts: 815 Joined: 26-February 04 From: Santa Cruz, CA Member No.: 1,724 |
Me too. Two weeks ago. I had a humming noise on the freeway. Louder when I changed lanes. Almost the same issue as you. Outer passenger side bearing was shot. No scoring of the race though. I ordered mine from Pelican because I could not find them in stock locally. Pretty easy to knock out the old races and put the new ones in. I left mine in the freezer over night but they didn't shrink as much as I expected. Light tapping around and around using a wood block worked. I also took some time to inspect my tie rod ends which also need replacing soon.
-Jeff |
Lo-Fi Version | Time is now: 1st June 2024 - 10:44 AM |
