Replaced some wheel bearings this weekend, How are yours? |
Rand |
Oct 28 2007, 08:15 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I know there are some of you out there who have never checked your wheel bearings. I recommend doing it. (IMG:style_emoticons/default/smile.gif)
I figured it was time to check mine. So, I jacked up a front corner to get a wheel off the ground. Grabbed the wheel and rocked it back and forth to feel for any slop. Drivers side good. Tried passenger side.... HOLY COW! WAY loose! Tried tightening up the nut a bit to see of the slack came out... No! Something's wrong. Removed the wheel. Removed the caliper. (A small rubber cork works perfect for plugging the line BTW.) Wow, that hub/disk was sloppy! Took it apart and found... Outer bearing toasted! Retainer shot and loose bearings inside! Outsch. The race on the bad bearing was also badly pitted. The inner race and bearings were fine, but my FLAPS had them all in stock and cheap - so I went ahead and replaced them all. My son enjoyed helping pack the grease and working the brake pedal at bleeding time. It's a cheap and easy job, so you might want to check yours out. (IMG:style_emoticons/default/smile.gif) |
lotus_65 |
Oct 30 2007, 07:06 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
i did my fronts a couple weeks ago, not too bad.
of course i came up with a trick... i wanted to make absolutly sure the bearings where fully packed, so i threw them in a ziplock half full of new grease and let my 6-year old daughter squish it for 10 minutes. she had fun, and i did less work! |
Lo-Fi Version | Time is now: 8th June 2024 - 12:09 AM |
