> won't start
plost
post Nov 3 2007, 07:22 PM
Tom
My 1.7 914 ran good for 5 years now it won't even fire.I have a 009 distributor with pertronix, no points. I do have a hopped up engine so the guy told me. He could not remember precisely but larger pistons and the heads are not stock. The car was running fine but steadily got harder to start until it wouldn't. The compression is min 120 max 130. The carbs IDF 44 have new kits in and have been soaked. I checked the static timing with an ohm meter, turned distributor clockwise (neg battery and neg coil) until it registered voltage then dropped it, then counter clockwise until voltage registered again so I think I'm close. Spark plug wires are 1-4-3-2. checked em 50 times. Have good spark. Set the valves too TDC .006. What the heck am I missing, spent three days on this and i'm not getting anywhere. Can anybody help me, it's gettin very frustrating.
plost
post Nov 4 2007, 02:27 PM
Tom
IT ran good last year, not so good this spring. Had an oil leak (covers) so I set the valves while I had hte covers off. I did it WRONG. Set 1 and 3 at the red timing mark. 2 and 4 were correct. It ran but not very good. They are set correctly now TDC no.1 on white mark compression stroke. Done the plugs 5 times. There could be a gas smell there can't really tell. What would that mean.
plost   won't start   Nov 3 2007, 07:22 PM
McMark   Set the motor at TDC for #1 (make absolutely doubl...   Nov 3 2007, 07:36 PM
drive-ability   I'm not a air cooled guy but did do tune-up wo...   Nov 3 2007, 07:46 PM
plost   Should I put the mallory with points back in and d...   Nov 3 2007, 08:19 PM
McMark   Does your old Mallory have replaceable springs? T...   Nov 3 2007, 08:36 PM
Headrage   Check the basics... Are you getting air (probably...   Nov 3 2007, 08:46 PM
rhodyguy   easy dist check. take the dist cap off. there shou...   Nov 3 2007, 09:15 PM
plost   OK thanks everyone I'm gonna put the Mallory b...   Nov 3 2007, 10:24 PM
McMark   Kevin, that's true if the drive gear is instal...   Nov 3 2007, 11:24 PM
plost   OK tried the mallory, dist. spark looks good, not ...   Nov 4 2007, 11:40 AM
davep   That is oil pressure. If the pressure stays up bet...   Nov 4 2007, 01:11 PM
plost   IT ran good last year, not so good this spring. Ha...   Nov 4 2007, 02:27 PM
davep   Gas smell says you are getting fuel into the cylin...   Nov 4 2007, 03:06 PM
swl   hey Tom. Here's something I stumbled on that ...   Nov 4 2007, 05:49 PM
McMark   If the green light is out when the motor starts cr...   Nov 4 2007, 06:03 PM
plost   Got the car running finally, thanks for all the su...   Nov 9 2007, 08:04 PM
George H.   Good to hear now what was the fix?   Nov 9 2007, 08:10 PM
plost   I had the PCV lines all crimped and pushed out of ...   Nov 9 2007, 08:21 PM
- Lo-Fi Version Time is now: 15th July 2025 - 08:28 AM
