| tracks914 |
Dec 13 2003, 10:30 AM
Canadian Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Pistons and Cylinders
I believe these are for a 2.0 L. Would they be of any use to someone rebuilding a 1.7? Price looks good but whats the catch? Tx Doug |
| tracks914 |
Dec 13 2003, 06:00 PM
I have 2 - 1.7's. One is complete and siezed.(spark plug missing) The other was running well when I bought the car and tore it down. Currently it is on the engine stand, stripped, and ready to split the crankcase and take journal readings.
I want to keep one of my engines original to stay with the car. So far it is all still "original". I'm just weighing out my options for the other engine. $229 for a complete set of cylinders, pistons and rings sounds pretty reasonable if I can make them work on one of my engines. Redoing the heads is not a problem but will things like, will my 1.7 engine tin fit over the 2.0 cylinders? What is the cc's of 2.0 heads vs 1.7 heads? Will they even fit on the 2.0 cylinders? Will it change the compression ratio to the point that I would have to run higher octane gas? Since the stroke is different would I end up with a 1.9L? Would a 1.9L work with the 1.7 FI or should it run carbs for a more variable set up? I have done a fair bit of mix and matching with V8's 305 to 350 - 318 to 340 to 360 (great success) and such but never with German engines. Sounds like a challenging project but I just don't want to waste my money. |
tracks914 Good Deal on Evilbay? Dec 13 2003, 10:30 AM
kwales Go over to Shop Talk Foums and do a search on "Wes... Dec 13 2003, 10:58 AM
Mark Henry It will give you the wrong deck height. You would ... Dec 13 2003, 11:03 AM
tracks914 The add states that pistons are dish topped. Optio... Dec 13 2003, 06:07 PM
Mark Henry You will have too much deck height and that means ... Dec 13 2003, 06:23 PM
tracks914 Can the 2.0 cylinders be machined down to a 66mm c... Dec 14 2003, 02:20 PM
DuckRyder 2.0 US pistons are dished.
2.0 Euro pistons are fl... Dec 14 2003, 02:28 PM
Mark Henry Your going about it the wrong way. If you don... Dec 14 2003, 02:36 PM
Brad Roberts The Euro's have a 3cc dish (not flat)
I have ... Dec 14 2003, 02:39 PM
tracks914 ![]() ![]() |
Lo-Fi Version | Time is now: 20th September 2026 - 02:47 PM |
