What does this wire connect to? |
mdwman |
Nov 9 2007, 08:36 PM
Member Group: Members Posts: 65 Joined: 28-May 07 From: Tennessee Member No.: 7,764 |
My recently acquired '73 1.7 is running well now after dwell angle, timing, and valves adjusted. Next step is scraping, treating, and painting some rusty spots; seems to be surface except battery tray is toast.
I discovered this unconnected wire that comes out from under the ECU. Can anyone say what it goes to? Could it be the reason I still experience seeking idle until the engine is warm? Thanks for any help! Attached image(s) |
McMark |
Nov 9 2007, 08:40 PM
For the optional oil temp sensor. Do you have an oil temp gauge (it would be in the center console most likely)?
orange914 |
Nov 9 2007, 09:17 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
For the optional oil temp sensor. Do you have an oil temp gauge (it would be in the center console most likely)? so this will go for the factory "taco plate"?? (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/piratenanner.gif) i added a taco plate to the new motor so i'll just run it to this lead? where does it come out and on the interior end and what does that end look like? (IMG:style_emoticons/default/confused24.gif) mike |
ClayPerrine |
Nov 9 2007, 10:05 PM
Life's been good to me so far..... Group: Admin Posts: 15,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
For the optional oil temp sensor. Do you have an oil temp gauge (it would be in the center console most likely)? so this will go for the factory "taco plate"?? (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/piratenanner.gif) i added a taco plate to the new motor so i'll just run it to this lead? where does it come out and on the interior end and what does that end look like? (IMG:style_emoticons/default/confused24.gif) mike Pull the carpet up by the heater handle. there will be a number of wires for the console. That is where the other end of that wire terminates. If you don't have a console, there was an optional temp gauge that went in the dash. |
orange914 |
Nov 10 2007, 12:12 AM
Pull the carpet up by the heater handle. there will be a number of wires for the console. That is where the other end of that wire terminates. If you don't have a console, there was an optional temp gauge that went in the dash. clay i have a console but not sure if its origanal. does this mean it may terminate in dash area? any idea of color? mike |
Lo-Fi Version | Time is now: 11th June 2024 - 04:06 PM |
