Fuel Injection woes |
G e o r g e |
Nov 12 2007, 03:14 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
OK
here my problem, I'm trying to use my previously functioning L jet system to break in my fresh rebuild, before i switch to an sds system. fyi I had removed everything from the engine bay for paint so everything is a fresh reinstall. which I'm sure is where my problem lies. I have spark, compression and fuel pressure, but no fuel coming from my injectors. I have checked my wiring over and over, and believe i am correct. I ,for the sake of argument, am a neophyte at best when it comes to this so any and all direction is appreciated. my ??? what causes the injectors not to fire ? is there a spot on the net that actually shows ( pics, diagrams)of the fuel injection harness connections? Where do I begin to test to get this system up and running? I would switch to sds, but the switch will be easier with the engine timed and able to idle as i work out the initial bugs. |
JeffBowlsby |
Nov 13 2007, 04:13 PM
914 Wiring Harnesses Group: Members Posts: 8,525 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Here is a link to an L-Jet manual.
http://members.rennlist.com/914_collectibles/zRareDoc06.pdf And here is a link to a draft L-Jet wiring harness diagram. I have better drawings, but they are not on the website yet: http://members.rennlist.com/914_wiring_harnesses/ (IMG:style_emoticons/default/flag.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:14 AM |
