> One cylinder poppin', Help me D-Jet gods!!
BiG bOgGs
post Nov 17 2007, 10:15 AM
The Bogus One
I pulled my 76 2.0 stock fuel injection engine a few months back so that I could plug up some oil leaks. Other than the leaks, the engine was running O.K. Well, as O.K. as I could tell after a couple of weeks of owning my first 914. I put the engine back in just a couple weekends ago and have slowly been trying to get her going again. For a couple of days I could only get her to spin with the starter, but I wasn't getting any fuel.....I figured out today that I hadn't connected the wiring harness to the distributor. Now that I have it connected I cranked her over and I am now firing on just the #3 cylinder. I also don't smell and raw fuel coming out of the exhaust. And when I open the throttle, she seems to power up a little bit, but not much.
major points
76 2.0L D-Jet
rebuilt/cleaned injectors from cruzin performance
new large and small injector rubber
new vacc. hoses all around
just had it tuned up before I needed to pull the engine and I didn't screw with the ignition system at all.
I hear no clicking when I move the throttle switch (thought I was supposed to hear the injectors clicking)
If there are any other bits of info that will help in the trouble shooting process please let me know.
Jim (n00b)
BiG bOgGs
post Nov 25 2007, 04:02 PM
The Bogus One
Well everyone, I have to first of all say thanks for all of your input. When I started this process, I never expected the result to be three bad injectors. With all of the wiring problems I have encountered when working with older systems I figured I just had a bad ground or improperly connected set of wires.
I have been soaking the three bad injectors in cleaner for most of the day now and have tested all four with my compressor and an old 9v battery. the good injector clicks strong and sprays well (at least from my eyeball view) and the other three make no sound at all. Boy on the positive side I din't encounter any leaking. (IMG:style_emoticons/default/rolleyes.gif)
So, as of now, I am in the market for a set of injectors. I am looking into stock replacement injectors, but am also considering some other newer alternatives like the injectors from a MB 450SE, that I heard one of our other board members has had some early success with. Any other new alternative suggestions are appreciated.
Again, Thanks!
Jim
BiG bOgGs   One cylinder poppin'   Nov 17 2007, 10:15 AM
Dr Evil   Jim, Make sure there are no broken ground wires fo...   Nov 17 2007, 10:48 AM
Dr Evil   Ah, a re-read your post and now see you are firing...   Nov 17 2007, 11:01 AM
BiG bOgGs   I have it running on just #3 because I disconnecte...   Nov 17 2007, 11:07 AM
Dr Evil   Are you sure that the others are receiving adequat...   Nov 17 2007, 11:22 AM
BiG bOgGs   Fairly sure they are getting good spark. Will che...   Nov 17 2007, 11:32 AM
Dr Evil   The injector fire diagonally. I forget the numberi...   Nov 17 2007, 11:38 AM
BiG bOgGs   At the rear of my harness, just to the passenger s...   Nov 17 2007, 11:39 AM
BiG bOgGs   Should I ground these 6 wires to the engine instea...   Nov 17 2007, 11:41 AM
BiG bOgGs   Dr, thanks for your help thus far. I now have to ...   Nov 17 2007, 11:50 AM
Dr Evil   Ding ding ding! Yup, those are supposed to be ...   Nov 17 2007, 11:52 AM
Dr Evil   Right on, if I think of anything else I'll pos...   Nov 17 2007, 12:06 PM
BiG bOgGs   Otay! I got the 6 wires connected to the male...   Nov 17 2007, 04:05 PM
Dr Evil   That question made my head hurt :rolleyes: Nope. Y...   Nov 17 2007, 04:19 PM
BiG bOgGs   OK DrE, thanks for the prescription. :headbanger...   Nov 17 2007, 05:25 PM
Dr Evil   Yup, that sounds right to me. Just check direction...   Nov 17 2007, 05:42 PM
BiG bOgGs   OK, I just finished checking the injectors. I pul...   Nov 18 2007, 02:43 PM
BiG bOgGs   Back from my little test. I ran a couple wires ac...   Nov 18 2007, 03:06 PM
Dr Evil   26 is too low. It should be 29psi and it should ho...   Nov 18 2007, 03:17 PM
Dr Evil   Actually, they should dribble even at the low psi....   Nov 18 2007, 05:05 PM
BiG bOgGs   Should I soak the injectors in anything to loosen ...   Nov 18 2007, 05:30 PM
Bleyseng   You can just send them out to be cleaned and teste...   Nov 18 2007, 10:20 PM
nola914   I suggest that you pull all four of the injectors ...   Nov 19 2007, 07:54 PM
BiG bOgGs   I suggest that you pull all four of the injectors...   Nov 19 2007, 09:13 PM
Tom   Make double sure you have the gas lines hooked up ...   Nov 20 2007, 12:44 AM
nola914   Tom reminded me of the fuel line issue. I forgot ...   Nov 20 2007, 08:58 PM
BiG bOgGs   OK! Some progress has been made in the diagnos...   Nov 23 2007, 09:57 AM
swl   sounds like a set of known good injectors would be...   Nov 24 2007, 08:42 AM
BiG bOgGs   sounds like a set of known good injectors would b...   Nov 24 2007, 11:17 AM
swl   I've heard a lot of people say not to use 12 a...   Nov 24 2007, 09:00 PM
BiG bOgGs   Well everyone, I have to first of all say thanks f...   Nov 25 2007, 04:02 PM
Dr Evil   That sucks considering you had them cleaned <_...   Nov 25 2007, 04:11 PM
swl   That is most bizzarre. You have to ask the questi...   Nov 25 2007, 08:24 PM
BiG bOgGs   Dr Evil and I PMed a little about getting me some ...   Nov 25 2007, 08:41 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:45 PM
