| BiG bOgGs |
Nov 17 2007, 10:15 AM
The Bogus One ![]() ![]() Group: Members Posts: 452 Joined: 25-September 04 From: Ft. Myers, FL 33967 Member No.: 2,829 Region Association: South East States |
I pulled my 76 2.0 stock fuel injection engine a few months back so that I could plug up some oil leaks. Other than the leaks, the engine was running O.K. Well, as O.K. as I could tell after a couple of weeks of owning my first 914. I put the engine back in just a couple weekends ago and have slowly been trying to get her going again. For a couple of days I could only get her to spin with the starter, but I wasn't getting any fuel.....I figured out today that I hadn't connected the wiring harness to the distributor. Now that I have it connected I cranked her over and I am now firing on just the #3 cylinder. I also don't smell and raw fuel coming out of the exhaust. And when I open the throttle, she seems to power up a little bit, but not much.
major points 76 2.0L D-Jet rebuilt/cleaned injectors from cruzin performance new large and small injector rubber new vacc. hoses all around just had it tuned up before I needed to pull the engine and I didn't screw with the ignition system at all. I hear no clicking when I move the throttle switch (thought I was supposed to hear the injectors clicking) If there are any other bits of info that will help in the trouble shooting process please let me know. Jim (n00b) |
| swl |
Nov 25 2007, 08:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
That is most bizzarre. You have to ask the question why they failed and is that condition still present? First thing I would be doing is checking the impedence to see if it is an electrical failure. If they are all the same then I would have a look at fuel delivery to see if there is a bunch of crap floating around in your lines. Not sure how to check for crap but I would somehow want to be sure this was just plain dumb luck before I put another set in.
BiG bOgGs One cylinder poppin' Nov 17 2007, 10:15 AM
Dr Evil Jim,
Make sure there are no broken ground wires fo... Nov 17 2007, 10:48 AM
Dr Evil Ah, a re-read your post and now see you are firing... Nov 17 2007, 11:01 AM
BiG bOgGs I have it running on just #3 because I disconnecte... Nov 17 2007, 11:07 AM
Dr Evil Are you sure that the others are receiving adequat... Nov 17 2007, 11:22 AM
BiG bOgGs Fairly sure they are getting good spark. Will che... Nov 17 2007, 11:32 AM
Dr Evil The injector fire diagonally. I forget the numberi... Nov 17 2007, 11:38 AM
BiG bOgGs At the rear of my harness, just to the passenger s... Nov 17 2007, 11:39 AM
BiG bOgGs Should I ground these 6 wires to the engine instea... Nov 17 2007, 11:41 AM
BiG bOgGs Dr, thanks for your help thus far. I now have to ... Nov 17 2007, 11:50 AM
Dr Evil Ding ding ding! Yup, those are supposed to be ... Nov 17 2007, 11:52 AM
Dr Evil Right on, if I think of anything else I'll pos... Nov 17 2007, 12:06 PM
BiG bOgGs Otay! I got the 6 wires connected to the male... Nov 17 2007, 04:05 PM
Dr Evil That question made my head hurt :rolleyes: Nope. Y... Nov 17 2007, 04:19 PM
BiG bOgGs OK DrE, thanks for the prescription. :headbanger... Nov 17 2007, 05:25 PM
Dr Evil Yup, that sounds right to me. Just check direction... Nov 17 2007, 05:42 PM
BiG bOgGs OK, I just finished checking the injectors. I pul... Nov 18 2007, 02:43 PM
BiG bOgGs Back from my little test. I ran a couple wires ac... Nov 18 2007, 03:06 PM
Dr Evil 26 is too low. It should be 29psi and it should ho... Nov 18 2007, 03:17 PM
Dr Evil Actually, they should dribble even at the low psi.... Nov 18 2007, 05:05 PM
BiG bOgGs Should I soak the injectors in anything to loosen ... Nov 18 2007, 05:30 PM
Bleyseng You can just send them out to be cleaned and teste... Nov 18 2007, 10:20 PM
nola914 I suggest that you pull all four of the injectors ... Nov 19 2007, 07:54 PM
BiG bOgGs
I suggest that you pull all four of the injectors... Nov 19 2007, 09:13 PM
Tom Make double sure you have the gas lines hooked up ... Nov 20 2007, 12:44 AM
nola914 Tom reminded me of the fuel line issue. I forgot ... Nov 20 2007, 08:58 PM
BiG bOgGs OK! Some progress has been made in the diagnos... Nov 23 2007, 09:57 AM
swl sounds like a set of known good injectors would be... Nov 24 2007, 08:42 AM
BiG bOgGs
sounds like a set of known good injectors would b... Nov 24 2007, 11:17 AM
swl I've heard a lot of people say not to use 12 a... Nov 24 2007, 09:00 PM
BiG bOgGs Well everyone, I have to first of all say thanks f... Nov 25 2007, 04:02 PM
Dr Evil That sucks considering you had them cleaned <_... Nov 25 2007, 04:11 PM
BiG bOgGs Dr Evil and I PMed a little about getting me some ... Nov 25 2007, 08:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:46 PM |
