Cable boot for turn signal bucket & side markers, Ran into a little problem today |
Pat Garvey |
Nov 25 2007, 07:45 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
Temps in the low 50's & sunny today, so I thought I'd wrap up a few unfinished things.
One of which was fitting some new boots, as mentioned in the title. These are PN 914.631.217.10, and are referenced for US/Canada/ROW in PET. Problem is that the small "tit" off the main boot for running side marker light wires through is blocked by a molded-in plug. Not the end of the world to drill/punch/carve out - just wondered what others had done when they encountered this? Don't want to screw the things up, because they aren't cheap. Pat |
GWN7 |
Nov 26 2007, 12:39 AM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
wood dowl the right size (to fit in the small end) and use a drill press for a exact sized hole
Pat Garvey |
Nov 26 2007, 08:06 PM
wood dowl the right size (to fit in the small end) and use a drill press for a exact sized hole Great idea Bruce, except I don't have a drill press. Guess I could just use my Black & Decker & eyeball it. Or, since the pluga appears to be about a quarter inch thick, I could just hand drill with a sharp bit. Or, I could use a mini Exacto to punch through & gradually widen it. My originals, which recently disintegrated in my hands do not appear to have had a plug in them. The wires to the side markers lights are encased in shrink tubing and the rear edge of the tubing resides well into the boot itself. I suspect the Factory had lots of ROW boots left, or decided to have manufactured only the ROW boots from some point on. My new ones were made in July '06. Pat |
GWN7 |
Nov 26 2007, 09:35 PM
wood dowl the right size (to fit in the small end) and use a drill press for a exact sized hole Great idea Bruce, except I don't have a drill press. Guess I could just use my Black & Decker & eyeball it. Or, since the pluga appears to be about a quarter inch thick, I could just hand drill with a sharp bit. Or, I could use a mini Exacto to punch through & gradually widen it. Now you have a reason to buy a drill press (IMG:style_emoticons/default/smile.gif) Use a drill bit just slightly smaller than the wires. That way when you push them thru the hole the rubber will seal against them keeping water/dirt out |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:53 PM |
