914 Track Suspension, Torsion Bar & Springs |
trapper |
Sep 22 2007, 10:02 PM
Newbie Group: Members Posts: 37 Joined: 6-February 03 From: Brighton, MI Member No.: 258 |
I need some suspension advice! I bought a 914-6 track car last spring and it is very soft. I don't know what I have installed yet but I suspect I need an upgrade over the winter. The car is a 2.8 liter with full cage. Any recommendations as to torsion bar size and rear springs? The car has front and rear sway bars, Bilsteins and monoball
front mounts. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/smash.gif) |
J P Stein |
Dec 2 2007, 11:36 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Are you using the 911 T bars....19 mm IIRC? If so, the 180s would be better.
I would highly recommend not using the stock underbody 911 AR bar as they are non-adjustable. A decent (Weltmiester) 19mm should do it for you. These do require U-tabs on the tops of your A-arms.......I'm hyphened out. (IMG:style_emoticons/default/biggrin.gif) I am not a fan of derlin. Elephant makes polybronze fronts also. |
Lo-Fi Version | Time is now: 29th May 2024 - 12:56 AM |
