> Got her running..., 4000 RPM idle speed!!!!
bpetry
post Dec 3 2007, 09:58 PM
OK, so I just got my '72 1.7 EFI running for the first time. Replaced all the vacuum and fuel lines and I thought everything was hooked up corectly per the pelican tech diagrams but after she fires up she idles for a few seconds and then zips right up to 4000 RPM (with no muffler I'm sure the neighbors loved that!). The throttle plate is almost all the way closed so it must be sucking air from somewhere else. I pinched off the big hose that goes from the plenum up near the oil fill and that seemed to slow it down a little, but I don't like letting it rev that high, especially when it hasn't been run in so long so I shut her off and figured I'd come in and ask the experts, any ideas?
Regards,
Brian Petry,
Springboro, OH
Dave_Darling
post Dec 4 2007, 02:38 AM
914 Idiot
You have a large air leak. Most likely you have a hose going straight from something "upstream" of the throttle (like the air cleaner, or the rubber hose from the air cleaner to the throttle), to "downstream" of the throttle body (like the manifold). There should never be any hoses that go directly from the one to the other, without having some "component" in the middle.
--DD
- Lo-Fi Version Time is now: 4th July 2025 - 10:41 AM
