URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,478 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I deleted my alternator (wire, tin, bolts, nuts, brackets, etc) and saved 18 pounds!!! (IMG:style_emoticons/default/smilie_pokal.gif)
Now I want to delete the relay board. But I need to know how to wire the starter in. I know I'll need some sort of voltage regulator or relay in the starter circuit. What have the others of you done? Thanks, Paul |
Group: Posts: 0 Joined: -- Member No.: 0 ![]() |
I want to eliminate as many wires as I can also. I want to use single switches for the necessary items such as fuel pump and battery cut out.
Lo-Fi Version | Time is now: 12th July 2025 - 10:56 PM |
