> I want to delete the relay board, How do I do this?
URY914
post Dec 15 2003, 09:43 PM
I deleted my alternator (wire, tin, bolts, nuts, brackets, etc) and saved 18 pounds!!! (IMG:style_emoticons/default/smilie_pokal.gif)
Now I want to delete the relay board. But I need to know how to wire the starter in. I know I'll need some sort of voltage regulator or relay in the starter circuit.
What have the others of you done?
Thanks,
Paul
sj914
post Dec 15 2003, 10:00 PM
As I recall, the thick yellow wire from the starter gets connected to the yellow wire of the main harness. The fuel pump, if your running carbs gets wired to a switched +12v. Now is that minimum enough.
- Lo-Fi Version Time is now: 12th July 2025 - 11:10 PM
