SteveL |
Senior Member ![]() ![]() ![]() Group: Members Posts: 663 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None ![]() ![]() |
Mom drives a 1997 Saturn SL1.
Last winter it had great heat. Once Warned up, temp guage was solid at 1/2. Over the summer, the radiator died. Replaced with brand new. I also replaced the thermostat with a standard replacement. Now, the temp guage only barely gets to 3/8, and it isn't hot enough to make good heat here in MN. Help Please? |
mudfoot76 |
Currently teenerless :-( ![]() ![]() ![]() Group: Members Posts: 946 Joined: 18-March 04 From: Carmel, IN Member No.: 1,814 Region Association: None ![]() |
Mom drives a 1997 Saturn SL1. Last winter it had great heat. Once Warned up, temp guage was solid at 1/2. Over the summer, the radiator died. Replaced with brand new. I also replaced the thermostat with a standard replacement. Now, the temp guage only barely gets to 3/8, and it isn't hot enough to make good heat here in MN. Could be that either the replacement t-stat is bad, or is the wrong temperature range for the car (ie - not the 'correct' replacement). Does it not heat up much, no matter how long you have been driving? Have you tried blocking off the radiator to see if that makes a difference? |
Lo-Fi Version | Time is now: 11th July 2025 - 03:18 AM |
